ABS
winslo
ABS
Post by winslo »
Got my BX out the garage last night. First time its been used since 1st October (it started first time)
Road a bit slippy and braked and wheels locked up? Car says it has ABS (badge on the rear) but never actually tried it before
Cant see any abs light when I turn ignition on
Any ideas?
cheers
1996 TZD (Kevs old car)
David
x 47
Re: ABS
Post by David »
On ABS cars the light should come on when the ignition is on, but should go out when you start the engine. Its in the bottom right of the instrument panel (in the rev counter or clock, which ever it has).
But remember, just because it has ABS, doesn't mean that you can't lock the wheels up. I have done it many times in my Xsara & the BX ABS system isn't as good.
Re: ABS
Post by citronut »
if it has ABS and its functioning correctly you should not be able to lock the brakes up
winslo
Re: ABS
Post by winslo »
I doubt a BX will have a OBD II port to find out if any faults?
Re: ABS
Post by Mothman »
No bud, it wont ime afraid. It will be trial and error whether you find the fault but i hope you do. I thank my TZD every day it starts, the ABS light comes on and then goes off.
Fingers crossed.
Re: ABS
Post by Tinkley »
I was under the impression, and stand to be corrected that ABS only works above approx 5mph? It might even be a little higher on the older ABS systems.
Re: ABS
Post by citronut »
winslo wrote:I doubt a BX will have a OBD II port to find out if any faults?
no it doesn't, but it does have an ABS ECU,
although i prefer to check/test the sensors at each sensor plug connector, others do this from the ECU pin outs
assembled
My Cars: 1991 Citroen BX TZD Turbo
1989 Citroen BX GTi 4x4
Re: ABS
Post by assembled »
ABS manual with all the important data:
http://www.bx16valve.co.uk/Files/abs.pdf
1992 TZD Turbo berline, aircon, ABS
1991 TZD Turbo berline
1989 GTi 4x4 berline, ABS
winslo
Re: ABS
Post by winslo »
Checked earlier and no abs light! Aaahhh!
Best get it into my mates garage see if he can find out whats wrong
ABS
I don't know if it helps but my current TZD has ABS but there's no light.... In fact there's no light unit behind the dash - the live wiring for the check light is still there (now safely insulated after a fire scare!) so presumably the ABS issue was not confronted, it was instead rather circumvented! Having had reason to brake recently there is no ABS and although the ABS badge (easily covered up or removed) might be an issue it did get its last MOT in this state a month before I collected it... Either that (sorry don't get me started: there were other major issues!) or the MOTs dodgy. So it's a case of devising a clever, let's say 'bypass' solution to the problem... Either that or do it (expensively) proper, like ;)
Last edited by Philip Chidlow on Sat Dec 13, 2014 2:43 am, edited 1 time in total.
ABS
Actually it brakes very well without ( it has new Michelins which helps)....
x 150
Re: ABS
Removal of the abs lamp is not an uncommon occurrence on older cars where cost of fixing it is prohibitive and difficult.
assembled
Re: ABS
Post by assembled »
Tim Leech wrote:Removal of the abs lamp is not an uncommon occurrence on older cars where cost of fixing it is prohibitive and difficult.
Often in combo with worn brake pads indication light romoval...
x 150
Re: ABS
I think both of mine still work but the abs on the TZI doesn't although I have tested the ABS in a Ivey road a few years back and it did work !
Re: ABS
Post by citronut »
if the warning lamp is removed the ABS will not function at all, if the ABS No. 14 fuse is removed the warning lamp will stay on
