Anyone know how to identify a hydraulic pump? Got the chance to buy a new old stock one but it doesn't have a part number I can trace (just a ticket with 460885). Seller says it's a 'five piston' type. RIng any bells with anyone?
Another seller has a pressure regulator (disjoncteur - bit the acc. sphere screws to). Seller says it's for BX but part number is 95 588 683 - which as far as I can make out os for a CX auto. BX part number should be 95 588 682. Anyone know what the differences are (If any?)
All help gratefully received - happy holidays by the way!
Hydraulic pump and pressure regulator - differences
KevR
- x 4
JayW
- x 13
Re: Hydraulic pump and pressure regulator - differences
AFAIK there are only 2 regulators. With PAS and Without.
Most people identify the pumps based on where the outlet is (i.e. how it mounts). I believe there are different pulley sizes but have never seen any.
I believe the five piston type is for a car without a fluid diverter valve for the power steering ie not a BX.
Known as a 3+2 (suspension + steering outputs).
JayW
- x 13
Erm, BX's DO come without PAS & FDV.Way2go wrote:I believe the five piston type is for a car without a fluid diverter valve for the power steering ie not a BX.
JayW wrote:Erm, BX's DO come without PAS & FDV.Way2go wrote:I believe the five piston type is for a car without a fluid diverter valve for the power steering ie not a BX.
But not with power steering directly driven from the pump!
JayW
- x 13
Your above statement is now correct with the edit
Isnt the 5 piston type for a xantia?
JayW wrote:Your above statement is now correct with the edit
Post not edited on bit you repled. I only added 2nd sentence showing the split function.
there is a 6+2 pump listed under BX on service citroen, not that i hjave ever seen one though
here is the list of all the different BX pumps
95 589 236
NFP
HIGH PRESSURE HYD PUMP
DIAM 120
PETROL
4007 T5
DIESEL FUEL AND 1,905L
PUMP 6 + 2
96 006 983
NFP
1 360L SINCE RPO 04193
95 638 565
NFP
GTI 16S UNTIL RPO 04223
96 034 023
NFP
GTI 16S SINCE RPO 04224
95 589 238
NFP
DIAM 90
DIESEL FUEL
95 589 236
NFP
DIAM 120
PETROL
4007 T5
PUMP 6 + 2
96 006 983
NFP
95 638 565
NFP
96 034 023
NFP
95 589 238
NFP
DIAM 90
DIESEL FUEL
