Front caliper thread stripped, best fix
x 137
I have a good pair of front calipers which i intend to fit to the t/d soon, as the present ones are binding slightly, i know they are from a low miles car and in good working order but the thread where the flexi screws in has been stripped/cross threaded on the nearside caliper,
Can it be repaired? Tapered thread?
Re: Front caliper thread stripped, best fix
Helicoil, loads of vids on Youtube.
http://www.helicoil.in/helicoil.htm
Post by citronut »
are you sure these have a tapered thread???? as the thread on the flexi dose not look tapered
Tapered thread was a question Malc.
Post by citronut »
Defender110 wrote:Tapered thread was a question Malc.
silly me
#-o :shock: :) :lol: :rofl: :rofl: :wink:
x 137
So fixable.. Wot is the thread size.?
Helicoil on a union thread? Hmmm, not sure on that, though I can't say I know for sure or anything. Normally HC would be the way out, but I would just bin it and get another from somewhere personally.
KevR
Post by KevR »
I've got a couple of brand new right hand side calipers available cheap if that's any help!
Post by citronut »
Kitch wrote:Helicoil on a union thread? Hmmm, not sure on that, though I can't say I know for sure or anything. Normally HC would be the way out, but I would just bin it and get another from somewhere personally.
i agree its probably not a good idea as this is brakes were talking here,
if you wish to try and reuse this caliper i wouls seek out an engineering company that could bore it outoversized, and make an adapter that the thread on the flexi will screw straight into
Helicoil leaves a stronger than original thread and I have had great success and have a lot of confidence in them however I do agree for the cost of replacement I personally would just fit a new calliper in this case.
It's not the strength of the thread that's the issue as you don't torque it up all that much. It's the boring/machining at the base of the drilling that potentially wouldn't seal properly against the union.
Kitch wrote:It's not the strength of the thread that's the issue as you don't torque it up all that much. It's the boring/machining at the base of the drilling that potentially wouldn't seal properly against the union.
:oops: :roll:
