I have a good pair of front calipers which i intend to fit to the t/d soon, as the present ones are binding slightly, i know they are from a low miles car and in good working order but the thread where the flexi screws in has been stripped/cross threaded on the nearside caliper,
Can it be repaired? Tapered thread?
Front caliper thread stripped, best fix
Re: Front caliper thread stripped, best fix
are you sure these have a tapered thread???? as the thread on the flexi dose not look taperedrutter123 wrote:
Tapered thread was a question Malc.
silly meDefender110 wrote:Tapered thread was a question Malc.
So fixable.. Wot is the thread size.?
- x 94
Helicoil on a union thread? Hmmm, not sure on that, though I can't say I know for sure or anything. Normally HC would be the way out, but I would just bin it and get another from somewhere personally.
KevR
I've got a couple of brand new right hand side calipers available cheap if that's any help!
i agree its probably not a good idea as this is brakes were talking here,Kitch wrote:Helicoil on a union thread? Hmmm, not sure on that, though I can't say I know for sure or anything. Normally HC would be the way out, but I would just bin it and get another from somewhere personally.
if you wish to try and reuse this caliper i wouls seek out an engineering company that could bore it outoversized, and make an adapter that the thread on the flexi will screw straight into
Helicoil leaves a stronger than original thread and I have had great success and have a lot of confidence in them however I do agree for the cost of replacement I personally would just fit a new calliper in this case.
- x 94
It's not the strength of the thread that's the issue as you don't torque it up all that much. It's the boring/machining at the base of the drilling that potentially wouldn't seal properly against the union.
Kitch wrote:It's not the strength of the thread that's the issue as you don't torque it up all that much. It's the boring/machining at the base of the drilling that potentially wouldn't seal properly against the union.
