Talking B____X
Re: Talking B____X
Post by Tinkley »
Why not? A few meters of 3.5 Cunifer will sort it.... :wink:
It actually seems like at around the 22-28 year old cars require a re pipe front to rear and new fuel pipes. If your really lucky with a never used in the salt car it might be a while longer, seems more an age issue tan abuse to be fair, and I don't doubt you have a decent car Philip. This age car also will be looking at a second replacement of cooling hoses and likewise front brake flexies. As for wishbone bushes and droplinks etc, well mileage may be more critical. One problem for carburettor cars is the age of the diaghrams and how they react to increasing levels of ethanol.
I'd be quite interested in running a steam or fuel cell powered BX but that may be possible in the next decade.... :wink: Even better with no road tax...remember 40 yr old vehicles pay none and it is now a rolling target...., please note Mothman!.
Re: Talking B____X
The car's back with me and initial impressions are good. Much, much better - I'm glad to report. But bloody hell, does it need a hoovering out, thorough wash and polish!
I'll have to see if it leaves a green calling card on the road over night, but hopefully sorted. Until the next thing: Actually there is still a list, including sunroof drain tubes, and this and that, as well as a few Challenge-specific jobs... but it's a much shortened list.
No pics until shiny!
Re: Talking B____X
I've had the GT 7 years plus and there are still little jobs to do on that Phil so don't worry!
x 117
Re: Talking B____X
You are doing well!
The lists on mine are getting longer all the time as I become less inclined to work on them myself.
But we don't have BXs to just look at and talk about do we, do we ?
Re: Talking B____X
Absolutely, J! I decided 'in for a penny, in for a pound'... It's cetainly proved a challenge to get this far, but what's the point of giving up?
Re: Talking B____X
Philip Chidlow wrote:Absolutely, J! I decided 'in for a penny, in for a pound'... It's cetainly proved a challenge to get this far, but what's the point of giving up?
More money in your wallet? :D
Re: Talking B____X
True. But what better way to spend it than on a BX? ;)
(Ha!)
Re: Talking B____X
Four course meal with a nice bottle of Chateuneuf du Papes, Liz by your side and a large amount of Brownie points to boot. :lol:
Re: Talking B____X
Bloody trouble-maker....
Re: Talking B____X
Right, the car's now something I really look forward to driving: I've put a few local miles on it, but it really needs a good run. It's still, however' dropping a bit of LHM, so it's not entirely fixed, but much better than it was. Forgot haw nice it was having new struts fitted.
New Speedlines and tyres to go on soon.
I'll wait for a few weeks (assuming the leak doesn't get worse) and get it checked again when it's serviced (and maybe, the ABS is replaced with the working loom/ECU I have here).
Then it's on to cosmetics - (I really can't face doing anything with the sunroof at the moment) - and fitting the newly acquired Sony head unit and door speakers.
Re: Talking B____X
A summary. Before the next phase:
Bought the car in August 2014 with an new MOT (ha! >:( ) from dodgy firm in Wolverhampton, with 91k miles showing.
Since then I've dried it out. (Which took a lot of patience!). Sunroof sealed up for now... drain tubes to do in the spring...
Here's a list of work carried out (much by Phil Boxall - a legend)... to this point, although there will be more week by week...
Cam belt changed. Waterpump, tensioner checked and good.
No leaks from camshaft ends.
Oil Change, filter change.
Fuel filter (Purflux) changed.
New rad cap.
Wiper blades.
Wiper nozzle fitting.
LHM replaced.
Accumulator sphere changed.
New headlights/Indicator lights fitted.
New higher power H4 bulbs.
New rear lights and bulbs.
New Michelin tyres x 4.
Driver’s door mirror replaced.
Driver’s window regulator replaced with new.
Rear headrests.
New number plates.
Replaced all dash bulbs incl. heater panel.
Rear fog lights repaired.
Fuel feed and return lines replaced.
Waxoyled underneath.
Replaced front discs and pads.
New front flexible hoses fitted.
New passenger side strut top.
Both front struts replaced. New OE return pipes/clips.
LHM tank/filters cleaned.
Replaced LHM and bled system.
Front splitter repaired.
Tailgate repaired.
Front wiper motor replaced with refurbished unit.
New seal around intercooler duct.
TZD decals replaced.
Rear arm bearings done.
New front spheres fitted.
Rear spheres replaced.
Rear discs and pads replaced. Brakes all bled.
Front N/S outer CV boot replaced.
New speedo upper cable fitted.
New stop solenoid fitted.
Welding to rear boot floor and exhaust hanger done.
New octopus and other oil harnesses replaced. Replacement high pressure pipe with curly (front subframe) fitted.
New steering coupling fitted.
More LHM poured into the tank.
Oh, and at least six treatments with Redex in that time too.
Re: Talking B____X
Still Leaking :(
Re: Talking B____X
Fggfggfffgffffgg!!!!!! :(
Ahh. That's better.
So it's off back to the workshop and get it sorted. Again :/
Re: Talking B____X
My GT has come out in sympathy Phil!
Re: Talking B____X
With age, comes incontinence. :oops:
