http://www.ebay.com/itm/251925872046
any thoughts Guys....is it worth a punt ?
For Sale on Ebay
For Sale on Ebay
1995 ZX D 178000
1995 XANTIA TD 162343
2000 Xantia 159011
1990 BXTXD 200,000
2000 Xantia 159011
1990 BXTXD 200,000
- Philip Chidlow
- x 25
Re: For Sale on Ebay
This car's familiar. I went to see it once but the clutch was fubar and it was a bit tatty. However this appears to have been relatively well looked after with new clutch etc. If the pump's leaking they are of course fixable but I think the Citroen Car Club might still have some Citroen-donated NEW pumps available to members for about £50. Or it could be leaking from the stop-solenoid seal (which mine was) which is a simple fix. Or, or.... probably worth a punt. But those trims need a repaint! lol
- x 141
That's been round the houses recently, as phil says it's worth a punt and the pumps are easy to source, in fact I have a spare one!
- My Cars: 1989 PH2 16v. White
Seat Leon FR. Whiter
I had the new clutch fitted to K179 RLN, I bought it because the previous owner was going to scrap it as the clutch had failed, I drove it home from Finchley to Northampton with no clutch which was fun, it's not the best BX around and as Tim says it's been passed around a bit, it's had at least three owners since I sold it to Willy a couple of years ago, I advise you to do a search on here with registration number to gain as much info as possible before you bid, I seem to remember one of the owners selling it because of a air getting into the system on the diesel side which meant it would cut out at low revs, which could explain the leaking pump possibly, the seller on eBay has put spares or repairs so may know more then their letting on ( only my opinion btw )
- themildbunch
Hope it's not the driveshaft seal leaking - quite common and needs the pump removed from the car - while old pumps can be cheap -you'd really want to reseal it before going to the bother of installation, new cambelt etc....
Changing the pump's not a 5 minute job either- probably at least half the value of a cheap diesel BX unless you DIY - I've just done two on our BX's!
1988 BX 19 Gti 16v
1991 BX 17 TZD Estate
