Disc Removal
artic-steel
Disc Removal
Post by artic-steel »
My BX failed it's MOT today on worn front discs & a split O/S CV boot, I removed the nearside disc no problem but the offside one is solid, i can't budge it, any tips?
Mr B
Northern Moderator
Northern Moderator
Post by Mr B »
Give the contact area between the disc and the hub a soak with Plusgas or similar, then give it a clout with a hammer. Take care not to miss and belt anything else :shock:
I take it you've removed the locating screws, yes of course you have :wink:
1991 Landrover Discovery
1995 VW Golf SE
artic-steel
Yes,they both sheared, oddly enough both N/S locating screws came out easy as well, i will go & soak it then leave it overnight
x 82
Alternatively remember the old discs are disposable so you can grind them to death or cook them to death!
Edited by Mr B
Stewart (oily!)
Post by Stewart (oily!) »
Big hammer, you know :twisted: it makes sense
Stewart
TZD 19 TD one of the few
Xantia Td estate, going soft
Ian_Fearn
Post by Ian_Fearn »
My old Cavalier discs were solid on too.
I started with a block of wood and hammer, in the end i resorted to a huge lump hammer and no block of wood. They shifted in the end.
Over and out from me
Post by jeremy »
I had the same problem with mine many years ago. Just a question of having enough courage to wallop it with a lump hammer.
BE CAREFUL - in theory the disc could shatter and you should protect yourself from the shrapnel that might be around. This means goggles and possibly some other protection for your body and head.
When the disc is off make sure that the hub face is very clean and flay (no rust) before you fit the new disc - so that it sits flat.
artic-steel
It's off, a puller,alot of heat & a big hammer did the job eventually
tim leech
Post by tim leech »
Goodo, theres no substitution for brute force and a big hammer!
Barnsley BXer
Post by Barnsley BXer »
tim leech wrote:Goodo, theres no substitution for brute force and a big hammer!
Oh yeah,my favourite tool is a big hammer :D :D :D :D :D My daughter says"whack it daddy"when I laugh,she says"No,whack it daddy,it always works" :D :D :D :D :D
1990 GTI 4x4
1992 TZD
tim leech
Post by tim leech »
:shock:
Adam
14lb Hammer For Sale!!!
Post by Adam »
I'll get you a BIG hammer from work!!!!!! :twisted:
Previously Owned
1988 19DTR
1991 17TZD
1987 19GTI (Dads)
1992 17DTR (Mums)
Currently
1991 19TGD
1991 TZD Turbo (Breaking)
"Graculus" 1990 TGD Turbo (Restoring)
