Black Carpet
x 139
Black Carpet
i think it comes as one, but need rear black carpet, they are all the same so any model is fine.
Thabks
Re: Black Carpet
G-SEG's is still here I think. Would be kinda fitting really!
x 139
Re: Black Carpet
thanks
Re: Black Carpet
If I've got it, it's yours gratis chap.
x 139
Re: Black Carpet
Thanks Kitch, could you post it rolled up at my cost?
Re: Black Carpet
Tim Leech wrote:Thanks Kitch, could you post it rolled up at my cost?
Should be able to sort something, yeah.
x 139
Re: Black Carpet
Thanks mate, also after some front fogs at some point (yes I know)
x 77
Re: Black Carpet
Tim Leech wrote: they are all the same so any model is fine.
The carpet is shaped and normally has a stiff backing (until it disintegrates) this means its tough to roll and that a 4x4 takes a different set so wont sit right in a saloon.
I've also found that early and late Mk2 front carpet sections can differ under the centre console (different cut outs and slightly different shape). These don't really matter as they can't be seen, but I thought it worthy of a note in case you get a carpet that doesn't appear to fit quite the same as the existing.
x 139
Re: Black Carpet
Thanks Vanny, you learn something new every day on this forum, G SEG should fit ok
