i think it comes as one, but need rear black carpet, they are all the same so any model is fine.
Thabks
Black Carpet
Black Carpet
- x 94
- x 94
Re: Black Carpet
Thanks Kitch, could you post it rolled up at my cost?
- x 94
Re: Black Carpet
Should be able to sort something, yeah.Tim Leech wrote:Thanks Kitch, could you post it rolled up at my cost?
Re: Black Carpet
Thanks mate, also after some front fogs at some point (yes I know)
- My Cars: BX 16v Ph2 - Jazz
BX 16v Ph2 - XPO - x 103
Re: Black Carpet
The carpet is shaped and normally has a stiff backing (until it disintegrates) this means its tough to roll and that a 4x4 takes a different set so wont sit right in a saloon.Tim Leech wrote: they are all the same so any model is fine.
I've also found that early and late Mk2 front carpet sections can differ under the centre console (different cut outs and slightly different shape). These don't really matter as they can't be seen, but I thought it worthy of a note in case you get a carpet that doesn't appear to fit quite the same as the existing.
Re: Black Carpet
Thanks Vanny, you learn something new every day on this forum, G SEG should fit ok
