BX 19 Diesel parts for sale
Dyane425
Post by Dyane425 »
New parts never used:
Head gasket + gasket set, sump gasket, cv joints, gaiters, clips and grease (pair), thermostat + seal + gasket, radiator cap, water pump + gasket, rear wheel bearing, 3 alternator belts, 2 hydraulic pump belts, 2 oil filters (Mann + purflux), 2x purflux Air filters, 1 Crosland fuel filter with all seals, 3 hengst fuel filters (only 2 have the main seal, but use Crosland seals as templates to get new seals). 2 aerosol tins of Venetian Red paint.
Following items used:
ns headlight, ns sidelight/indicator unit (Mk II), 3 x windscreen washer reservoirs, sunroof motor bosch 0390201697, Nsr bulb circuit board Citroen part number 95587054. Open door warning (showing outline of the car) used on high spec TR/TZ/GTi models.
Relays which go under the passenger glovebox.
Nsf inner wing guard (plastic). 1x R/TR peppercot hubcap, 2x TZ hubcaps
Ideally, I want to sell this as a job lot. Collection only.
Offers invited.
I live in Brighton, but will be in Chelmsford in Essex on alternate weekends. I can deliver free of charge within a 5 mile radius of Chelmsford or Brighton, depending where I am.
I will be at the Citroen GS/A & Ami Rally at The Rural Life Centre, Tilford, Farnham, Surrey on Sunday, 9th August, and will have the BX parts with me then.
Please contact me to arrange collection.
