New parts never used:
Head gasket + gasket set, sump gasket, cv joints, gaiters, clips and grease (pair), thermostat + seal + gasket, radiator cap, water pump + gasket, rear wheel bearing, 3 alternator belts, 2 hydraulic pump belts, 2 oil filters (Mann + purflux), 2x purflux Air filters, 1 Crosland fuel filter with all seals, 3 hengst fuel filters (only 2 have the main seal, but use Crosland seals as templates to get new seals). 2 aerosol tins of Venetian Red paint.
Following items used:
ns headlight, ns sidelight/indicator unit (Mk II), 3 x windscreen washer reservoirs, sunroof motor bosch 0390201697, Nsr bulb circuit board Citroen part number 95587054. Open door warning (showing outline of the car) used on high spec TR/TZ/GTi models.
Relays which go under the passenger glovebox.
Nsf inner wing guard (plastic). 1x R/TR peppercot hubcap, 2x TZ hubcaps
Ideally, I want to sell this as a job lot. Collection only.
Offers invited.
I live in Brighton, but will be in Chelmsford in Essex on alternate weekends. I can deliver free of charge within a 5 mile radius of Chelmsford or Brighton, depending where I am.
I will be at the Citroen GS/A & Ami Rally at The Rural Life Centre, Tilford, Farnham, Surrey on Sunday, 9th August, and will have the BX parts with me then.
Please contact me to arrange collection.
BX 19 Diesel parts for sale
Dyane425
