How do i get the CV off the driveshaft to replace the boot?, i can't see or feel a circlip.
Sorry for the basic questions but i'm new to this & without a haynes manual for the time being.
CV removal
Mr B
- Northern Moderator
Stewart (oily!)
Peel back the rubber and bend the joint to max articulation, look inrto the joint, you should see the inner part adjacent the shaft, tap his smartly with a light hammer and the CV should fall off, theres only a wire circlip holding it on, where in North Wales are you? Im in Wrexham,
Stewart
Stewart
TZD 19 TD one of the few
Xantia Td estate, going soft
artic-steel
Stewart (oily!)
artic-steel
