BX 19 TZD hatch n/a diesel auto for sale
themildbunch
Post by themildbunch »
The time's come to move on this one I bought from a forum member back in 2011.
It's a 1.9 non turbo diesel auto hatch - here's two images from then - main exterior difference now is a full set of correct TZD wheel trims and a replacement rear hatch with the correct 19 TZD name plate (but not fitted!)
MOT until May 2015
£350 ono
This is a naturally aspirated 1905cc diesel with the ZF 14HP4 autobox so it's not very fast! It does have the Bosch VE diesel pump though and being TZD spec has nice supportive harder wearing velour seats, etc..
Judging by the condition when I got it this car looks like it probably had a gentle early life, possibly garaged as there's little of the 'hidden' rust that can affect BX bodyshells. Both front door hinges are pretty much perfect and haven't ever been welded.
Recently this car's had a fair bit of work done to it, mostly by me and some by our local Citroen Specialist, Tony & Andy Weston in Cambridge, near Dursley, Gloucestershire.
In the last couple of months:
  • Removed diesel pump to replace driveshaft seal and some others.
  • All injector leakoff pipes replaced
  • replaced original fuel filter and housing with new, leak free type and all filter to pump hoses
  • Fitted new cambelt, camshaft seal and crank seal.
  • Fitted genuine bottom coolant hose and thermostat bypass hose
  • Fitted new genuine front brake discs and pads
  • Fuel tank lowered to replace perished and leaking breather pipe
  • Replaced rear suspension spheres
In the last 6 months:
  • brake doseur low pressure return pipe repaired (MOT)
  • Steering Coupling (Hardy Disc) replaced (MOT)
  • Nearside steering rack boot replaced (MOT)
  • Nearside track rod replaced (MOT)
  • Fitted new diesel feed and return flexible pipes (MOT)
  • Drained and flushed hydrualic system with hydraflush, cleaned filters and replaced with new LHM
  • Cooling system flushed and replaced with long life coolant
  • Oil and filter changed.
  • High Pressure pump side camshaft seal replaced
  • Heater fan motor control module replaced.
In the last 2 years:
  • Fitted 2 x front suspension droplinks
  • Fitted new waterpump
  • Fitted new accumulator sphere
  • Replaced all old automatic transmission fluid with Dextron II
  • All glowplugs replaced with new Beru ones.
Remaining 'issues' I haven't got around to resolving and have just lived with are:
  • Auto has a tendency to flare (slip into neutral) if pushed hard in it's lowest gear when pulling away. It doesn't do it in other gears and kickdown seems to work fine. It'd perfectly driveable though and not being a fast car I've just got used to it! I had planned to do a manual conversion but I have 2 other BX's and not enough time so someone else can do this if they like...
  • At some point in it's previous life some airhorns had been fitted with relays and the ignition switch replaced (2 keys now). In the process some wiring had been altered and / or bodged and this could do with looking at and some of it replacing with new cable. The starter solenoid sometimes sticks on starting once the cars hot – a few starting attempts always fixes it though. The oil level gauge in the dash doesn't work and the radio is wired to switch off with the ignition... None of this is very terminal and easily sorted..
  • In very cold weather the power steering can be a little notchy before the LHM has warmed up.. This is either a weak HP pump (s/h one supplied with car) or dirty filters in the flow valve – quite a common issue and shouldn't be difficult to resolve. Hasn't got bad enough to be an MOT failure... Disappears when running with hydraflush!
    Paint has lost some of it's laquer the worst places being the bonnet and roof. Most of the panels have a scratch or two too..
  • Heater control valve a bit sticky – heater control will go cold but only go to ¾ hot... Works fine though and gets hot enough to keep comfy and clear screen – fan blower works well though at all speeds. The valve near the bulkhead would really need replacing and I can supply one if necessary.
1988 BX 19 Gti 16v
1991 BX 17 TZD Estate
Re: BX 19 TZD hatch n/a diesel auto for sale
Sounds like a nice car, & at that price an absolute bargain :D
I've driven this, thought it was lovely. And at that price, a steal.
patersom10
Post by patersom10 »
Pm sent
93 ZX Volcane TD
92 BX 16v phase 2 - now sold
93 BX 17TGD - now sold
themildbunch
Haven't had your PM yet... think my mailbox was full...
1988 BX 19 Gti 16v
Very cheap car!
x 141
Sold ?
x 141
Did this sell? Adrian?
oladiti
Post by oladiti »
Hi Mathew,
Im relatively new on this forum, can you please advice if you still have your bx Auto (H161FJP) for sale.
I am genuinely interested in it, or a similar one, or perhaps a lead for a good one like yours, in the event that you no longer have it.
Please feel free to contact me on 07951 663 424.
Thanks Ollie.
themildbunch
This TZD will be back up for sale in the spring - decided to repair some of the niggles and use it rather than sell as it is...
Replacement HP pump already fitted so now perfect power steering..
Intermittent starter now repaired too...
1988 BX 19 Gti 16v
oladiti
Post by oladiti »
Hi,
I sent you a message a week ago, if this car is still available.
Am still interested, is there a contact telephone number to reach
you on, my tel No is in my previous message.
Thanks
Ollie
themildbunch
I've decided to put this car up for sale again.. Probably too cheap last time and the wrong time of year!
Since the original ad - at the top of this thread H161 FPJ has had some more work done my myself and our local specialist (Tony Weston):
  1. Another years MOT
    2 x new ball joints fitted
    Front spheres re-gassed to standard
    Rear set of brake discs and pads fitted with new fitting kit
    2 x front tyres + tracking adjusted on a Hunter machine (steering is a joy now, very light and tracks perfectly)
    Oil filler pipe to sump breather pipe replaced (a common source of oil leaks)
    Some of the starter circuit wiring replaced to help resolve intermittent no start 'click'!
I'll post more pictures later tonight.
With the recent MOT and extra parts fitted, looking for £550 ono..
1988 BX 19 Gti 16v
Thats still v-cheap if you ask me, surely someone is going to snap this one up?
