Hello all, I've ask this before some time back
my valver when I start up the rev's go high after
about a mile it calms down to normal running.
Right now I've taken of i.c. valve just sprayed with
wd 40 do I need to do more. please tell me
Valver calling
- x 88
Re: Valver calling
Coolant temp sensor?
- x 26
Re: Valver calling
I get this too - especially in the winter. Accompanied by revs waving up and down from 500 - 2000 rpm.
In my case it's not the coolant temp sensor but I can fully understand why that might be a logical port of call.
I'm planning on overhauling all the air inlet/bypass hoses to double check there aren't any leaks will report back.
What other engine management sensors are temperature-dependent apart from the CTS?
- x 88
Re: Valver calling
Air flow meter has an air inlet temp sensor i think.
- themildbunch
Re: Valver calling
also worth checking the springs for the butterfly valves on the throttle body, these often break or become loose...one of mine has and I get a slightly high idle as a result..
1988 BX 19 Gti 16v
1991 BX 17 TZD Estate
Re: Valver calling
Airleaks are usually the cause of erratic rpm's, my gti suffered from this i ended up completely removing the SAD (choke valve) and blocking up the air inlet/outlets.
- greendale65
- x 20
Re: Valver calling
Ok all, Thanks for advice gives me something to aim for.
when its running on the low revs its so docile but goes
like a rocket. when pedal down.
U can see photo of my valver
listed valver in west bay
Dorset.
Dorset.
