Diesel Air inlet pipe?
Does anyone happen to know the function of the cardboard foam pipe that lets air into the air filter box on some diesels ( mines a 1700)? The one I have is past best to say the least... Are they still available or shall I take it off and throw away?
Bx turbo diesel 1989
Bx 1.9 Rd estate 1989
Citroen Light 15 1952
Bx 17 TZD diesel turbo 1992
Xantia 1.8 16v
Xantia 1.8 16v
- x 148
Re: Diesel Air inlet pipe?
It funnels cold air into the engine, from the inner wing which the colder the air the fender it is and will give a better burn. I would try a and keep it in place of you can.
It's just mines falling apart and I was wondering how critical it was noting it has foam inside and the odd hole here and there......so I could substitute it for something else ?
Xantia 1.8 16v
Xantia 1.8 16v
- ken newbold
If it's the one that runs from the wing to the air filter, it's not a problem, but if it runs from the air filter to engine you need to replace it.
- My Cars: BX 19 TRD 1985
CX GTi 1986
If you remove the paper pipe with foam inside, the suction noise will be definitely louder. There are small holes on that paper pipe, to have (or eliminate?) the air-spring effect in the pipe.
I had a plastic pipe without foam and holes, and as I have changed to the factory version, the noise reduced. No other benefits I realized.
Out of a matter of interest are the factory ones still available and if so any idea on price?
Xantia 1.8 16v
Xantia 1.8 16v
- x 148
You'll possibly find a new one on eBay or a rally, not available new from Citroen, last ones I saw available was £30.
