Pump Running
- x 148
Pump Running
New regulator and accu sphere fitted today and no more leaks but disappointed that the pump still cuts in at idle as before but cuts out when revs lift slightly.
Any ideas?
Any ideas?
- ken newbold
- saintjamesy89
198x Citroen BX16 TRS auto
1991 Saab 900 16v convertible
2007 Lexus RX 400h SE - x 124
Re: Pump Running
I've noticed mine does this too Tim, I had mine down to lack of use and dirty LHM filters though (still haven't cleaned them out yet!). Be interesting to see what, if anything, causes this.
I wonder if it's anything to do with what spheres you have fitted? ie comfort spheres having higher pressures than some others.
2006 Lexus RX 400h SE hybrid
- x 148
Re: Pump Running
Ken
If you turn the car off and raise the suspension it has enough in reserve to put the rear all the way up! Also it lifts up of its haunches when cold quickly.
The lhm and filters are all new, the spheres are from 2004 but the ride is brilliant so I'm loathed to change them.
- ken newbold
Re: Pump Running
My xm did the same, slight touch of the steering wheel would stop it, so I assumed the ram was the problem, does yours?
- x 88
Re: Pump Running
BAH does this too. It's been suggested to me that it's a leaky strut, but I haven't even looked at it and it's been doing it for 3-4 years. Apparently it can kill the pump though, so I really should!
- x 148
Re: Pump Running
Struts seems ok, there's no leak from outside the strut body?
- x 88
Re: Pump Running
It'd be an internal leak. You need to check the return hoses to the reservoir.Tim Leech wrote:Struts seems ok, there's no leak from outside the strut body?
Re: Pump Running
Yup, the returns on good spheres will have virtually zero leak back where knackered struts seals will allow a flow of LHM back to the tank and really knackered struts blow the return pipes off at joints as they can't handle the excess flow.Kitch wrote:It'd be an internal leak. You need to check the return hoses to the reservoir.Tim Leech wrote:Struts seems ok, there's no leak from outside the strut body?
- x 148
Re: Pump Running
Ahh ok chaps, guess I will just live with it!
- Dragon Man
- My Cars: Citroen Dispatch 2.0L HDi 2005
Fiat Panda 4x4 Sisley 1991 - x 6
Re: Pump Running
good info here guys, i'll be sure to check this when i get my BX.
- JohnDragonMan
Drives: Citroen Dispatch with retrofitted air conditioning
always buy base spec. that way you have the fun of putting all the cool bit on your vehicle
