For sale BX Lock set
x 137
Ignition barrel, 2 door locks and fuel cap, all on same key, with 2 keys.
£25 set + £3.50 postage
Glyn
My Cars: citroen bx 17rd
Re: For sale BX Lock set
Post by Glyn »
Hi, would this fit my 1989 bx 17Rd please? Is the ignition barrel in good nick? Thanks
x 150
Afaik all mk2 diesel sets are the same so yes it should
x 137
Glyn wrote:Hi, would this fit my 1989 bx 17Rd please? Is the ignition barrel in good nick? Thanks
Yes it will fit your car all mk2 bx's have the same locks.
Ant4567
My Cars: Citroen bx 16rs mk 1
Land rover series 3
Post by Ant4567 »
Long shot but do you still have the door locks and know if they would fit a mk1 estate
Sent from my SM-J500FN using Tapatalk
x 137
Pretty sure they will, yes i still have the lock set.
Maybe someone could confirm?
x 150
Petrol and diesel ignition locks I think are different but the door/filler locks are the same on all models. Mk1 doesn't have a lock on the glovebox anyway.
Tim Leech wrote:Petrol and diesel ignition locks I think are different but the door/filler locks are the same on all models. Mk1 doesn't have a lock on the glovebox anyway.
Yes diesels have an extra wire on the ignition barrel for the heater plug circuit. Diesel ignitions can be used for petrol's but not visa versa.
x 83
@Defender: Really ? Isn't the extra circuit in the diesel car loom not in the ignition switch as there is no extra room for another cable except for the extra connector for the ABS circuit.
@Tim: I reckon the switches diesel/petrol are identical and interchangeable. Not sure about Mk1 and 2 being the same though as I have never owned a Mk 1.
Jaba wrote: @Defender: Really ? Isn't the extra circuit in the diesel car loom not in the ignition switch as there is no extra room for another cable except for the extra connector for the ABS circuit.
Yes sorry I was treating it as the complete unit, barrel & switch. The barrels on there own should be interchangeable.
x 137
Im with 110 on that one sure MK1/2's are the same ign and door locks think wiring is same on both petrol or diesel.
Ant4567
Land rover series 3
Post by Ant4567 »
Only need the door locks looks like somebody once tried to nick mine before i owned it
x 137
i can do you just the door locks if needed, but will only give you one key as i will need the other key for the ignition barrel, £10 plus £2 post if ok.
Ant4567
Land rover series 3
Re: RE: Re: For sale BX Lock set
Post by Ant4567 »
rutter123 wrote:i can do you just the door locks if needed, but will only give you one key as i will need the other key for the ignition barrel, £10 plus £2 post if ok.
Yeah that would be great cheers sorry for the slow replies spent all night trying to sort a overheating issue out. Do you want payment via paypal?
