Not BX, but....
Not BX, but....
Anyone know anything about the infernal electronics on Hdi 110's? My 02 Picasso travels precisely 11.2 miles then goes into limp mode. Diagnostic says Clutch switch high (so I've disconnected it), Throttle position sensor circuits A&B (So I've replaced it albeit with a breakers yard one) and System Voltage (Not sure what that means). its getting progressively worse, and since my daily commute is 40 miles each way, increasingly traumatic. The only way I can keep it going is by feathering the throttle and the clutch. Any ideas gratefuly received
Dom
91 TZD
02 Picasso HDI
'12 DS5
83 Moto Morini 500
70 Fiat 850 Spider
Anything that turns money into noise...
91 TZD
02 Picasso HDI
'12 DS5
83 Moto Morini 500
70 Fiat 850 Spider
- xjs36uk
- My Cars: 87 Capri 3.0S
87 XJS 3.6
91 BX 1.6 IE Image
91 W124 250D Kombi
93 Xantia Phase 1 1.9TD SX
93 XJ40 4.0 Sport
95 X300 3.2 Sport
97 LDV Convoy
99 P38 2.5DSE
83 Kawasaki GT750
85 Yamaha XT500 55W
86 H**da CBR500R
86 Kawasaki GPZ1000RX
86 Kawasaki GTR1000
88 Kawasaki GTR1000
89 Kawasaki GPZ900R
90 Kawasaki ZZR1100C
00 Kawasaki ZX12R - x 2
Re: Not BX, but....
Without being able to pinpoint an exact fault, system voltage low would suggest the main power circuit, so check the battery for min 12.5+ volts holding at rest (slow climbing is also ok but indicates battery is not fully charged) and altenator output with engine running (all ancillaries off), which should be steady at min 13.4v + above 1200rpm (fluctuations in altenator voltage will normally be regulator/rectifier).
Modern electronic systems are incredibly sensitive to voltage changes and a tired battery or altenator will cause the ecu's the report a non existant problem and switch to limp mode or immobilisation mode. It's the first step.
87 Capri 3.0S
87 XJS 3.6
91 BX 1.6 IE Image (just sold)
91 W124 250D Kombi
93 XJ40 4.0 Sport
95 X300 3.2 Sport
97 LDV Convoy
99 P38 2.5DSE
99 E280 4-Matic Estate
83 Kawasaki GT750
85 Yamaha XT500 55W
86 H**da CBR500R
86 Kawasaki GTR1000
88 Kawasaki GTR1000
89 Kawasaki GPZ900R
00 Kawasaki ZX12R
If you cut me I bleed Green
Mark
87 XJS 3.6
91 W124 250D Kombi
93 XJ40 4.0 Sport
95 X300 3.2 Sport
97 LDV Convoy
99 P38 2.5DSE
83 Kawasaki GT750
85 Yamaha XT500 55W
86 H**da CBR500R
86 Kawasaki GTR1000
88 Kawasaki GTR1000
89 Kawasaki GPZ900R
00 Kawasaki ZX12R
Mark
- x 150
Re: Not BX, but....
I have a broken Picasso at work 1.6 110 with a blown turbo if you want a spares car!
- x 88
Re: Not BX, but....
Didn't do the 110 Picasso in 2002 did they?!
What diagnostics are you using?
Re: Not BX, but....
Battery a good place to start, sounds like. Diagnostics is a cheapy Konnwei jobby, And yes, the 110 Picasso has been around since 2000! It is the 8v one, mind.
Dom
91 TZD
02 Picasso HDI
'12 DS5
83 Moto Morini 500
70 Fiat 850 Spider
91 TZD
02 Picasso HDI
'12 DS5
83 Moto Morini 500
70 Fiat 850 Spider
Re: Not BX, but....
Dom
91 TZD
02 Picasso HDI
'12 DS5
83 Moto Morini 500
70 Fiat 850 Spider
91 TZD
02 Picasso HDI
'12 DS5
83 Moto Morini 500
70 Fiat 850 Spider
- x 88
Re: Not BX, but....
Erm, no, the 110 came out in 2004. It was a 1.6 16v. The 8v is a 2.0, and only came in 90bhp guise.Dominic wrote:Battery a good place to start, sounds like. Diagnostics is a cheapy Konnwei jobby, And yes, the 110 Picasso has been around since 2000! It is the 8v one, mind.
Cheapo OBDII readers are often a waste of money. Get on to FCF and find someone who's nearby with a Lexia.
When my '04 Piccaso did this, it turned out to be air flow meter, even though it showed nothing on diagnostics. Not saying it's the same for you, but that's what it was on mine.
- x 88
Re: Not BX, but....
Not if it's an 02 it's not.Tim Leech wrote:This is a 1.6 16v Hdi
