TIMS BX BLOG
Re: TIMS BX BLOG
Tim Leech wrote:plus satnav and a TV! yes a TV (no longer works as Analogue has been turned off)
Yes my Volvo too has a defunct Satnav / TV which pops up out of the dash.
Re: TIMS BX BLOG
Any way you can get one of these TV to play DVDs though?
Re: TIMS BX BLOG
Possibly but as the headunits pretty much useless I'll replace it with a up to date one.
Re: TIMS BX BLOG
Not sure mine is linked to a disc machine in the boot as the Satnav is on a disc, I'll have to give it a whirl.
Re: TIMS BX BLOG
Here she is In all her glory,
Not bad for £200!
Re: TIMS BX BLOG
You can part the SD1 out now then ???????????????? ;-)
Re: TIMS BX BLOG
No.
Re: TIMS BX BLOG
They're breeding....
demag
Re: TIMS BX BLOG
Post by demag »
Hope the boots are dry Tim. I was looking at a 2l auto v6 until I noticed the urban mpg. Err no thanks.
Sent from my Wileyfox Swift using Tapatalk
Dave.
1990 Bx TGS automatic.
Re: TIMS BX BLOG
HI Dave
Both are fine, and have had the rear light seals sorted.
Re: TIMS BX BLOG
The challenge looms so it's all about the Gt at the moment, I've been making do with a leaky sunroof that only opens and needs a thump to shut. I bought a complete headlining and used sunroof off Cliff last year which I decided to finally tackle today.
It's an awkward labour intensive job but not hard. The replacement headlining wasn't good enough to go in and had the cables hanging out so I took them both apart and made one good one out of the too. The sunroof in the GT had a few broken pieces and one of the cables was badly kincked and seized.
I took it apart and oiled all the cables etc and put the replacement sunroof panel into my headlining. Putting the headlining back in with the sunroof attached was hard work, I had to do it that way as the screws on the replacement panel were rusted and rounded off.
Anyway all back together and one filthy headlining and a small dent on the roof later fir the first time it tilted and slide back......once.
It now does the same as before, pops up easily, but the drivers side will not close without manual help and it won't slide back as it sticks.
I've also noticed since the new radiator fitted the heater tap is dripping inside the car.
(It's going to Barry's on Monday and I will let him look at the tap as I can't stand to work on it right now.
To say I'm pissed off is an understatement.
I'll just keep the sunroof shut from now one, the only upside is the drain tubes are clear.
My Cars: 1985 Citroen BX19 GT
2013 Nissan Leaf Acenta 24Kw
x 199
Re: TIMS BX BLOG
Post by saintjamesy89 »
It's a bugger when you go to a lot of work on a car and still haven't fixed it! I'm sure in time it'll be solved. It's a shame about the heater tap too, how dod you notice - were the carptes wet?
Keep on GTing Tim!
Re: TIMS BX BLOG
I noticed a very small puddle of water on the drivers rubber floor mat.
Re: TIMS BX BLOG
GT passed the MOT, well it failed first time as the nsr seatbelt was sticking, a bit of lube and some use and all is well
New rear spheres (all soft and lovely again) and Michelin tyres fitted, and its ready for Bourne on Wednesday for it pre-challenge check up.
Just waiting to hear if the Athena will be ready for Monday so I can swop them over.
The water leak from the tap has now stopped... :shock:
Re: TIMS BX BLOG
Enjoy the Challenge (and France) mate. Bon Voyage. :)
