Annoyingly, just on an earth fault on the rear lights, I should have spotted it. I cleaned up the earth connections which seemed to do the trick but as I couldn't quite tell whether there was some optical illusion between the indicator and tail light I decide to dismantle the rear light at which point three of the bulbs fell apart! Apart from numberplate lights I don't recall ever replacing any rear bulbs so they must be all at least 17 years old and had obviously deteriorated with age. Something to check.
Re-test tomorrow afternoon.
MOT failure!
deltic
- x 51
MOT failure!
Re: MOT failure!
I had this on mine a few years ago where the taillight was dimming slightly with the indicator on, just earthed direct to the body, problem solved.
- x 116
Re: MOT failure!
Me too. I have soldered in big fat earth cables from the PCBs to the bodywork earth terminal. Annoyingly my MOT tester was keen on checking for the dimming interference from the indicators.
