Tin worm
x 138
Tin worm
Just cut away the nearside sill revealing this.....
panky
'88 BX GTi (a long time ago)
x 169
Re: Tin worm
Post by panky »
Yuck, I think you found the nest.
Looks similar to what I found on my Minor Traveller :?
x 138
Re: Tin worm
It's bad, it's really bad, the whole area is shot.
panky
x 169
Re: Tin worm
Post by panky »
Don't be too disheartened anything can be fixed.
My Traveller went from this
to this
in about 18 months, and that doesn't show the majority of the rot :roll: But I'll crack on until it's done then hopefully sell it and buy a valver :D
x 138
Re: Tin worm
Well looking at your Traveller on balance mine is fairly mild, there was only one of the original spot welds holding the top plate in situ, the rot has eaten away most of the mounting area and a good 6 inches of the inner sill and lower front inner wheel arch. Yes I can repair it but I'm gonna try to do it from the top by cutting away some of the internal metal and welding it back in after, otherwise it's rear axle out and fuel tank which makes it a big and no doubt more costly job. Luckily I've managed to salvage what's left of the top plate so I have a pattern to work to. Sadly this area of rust saw the demise of many bx's.
panky
x 169
Re: Tin worm
Post by panky »
Would love to see how you tackle it as I've never done any major repairs on a BX. At least with the Morris there's no problem getting new panels - I just need a lot of them.
Re: Tin worm
Loving the Traveller ;-)
panky
x 169
Re: Tin worm
Post by panky »
Thanks. It will be beautiful once more - hopefully :D
panky
x 169
Re: Tin worm
Post by panky »
rutter123 wrote: Mon May 28, 2018 8:54 pm Well looking at your Traveller on balance mine is fairly mild, there was only one of the original spot welds holding the top plate in situ, the rot has eaten away most of the mounting area and a good 6 inches of the inner sill and lower front inner wheel arch. Yes I can repair it but I'm gonna try to do it from the top by cutting away some of the internal metal and welding it back in after, otherwise it's rear axle out and fuel tank which makes it a big and no doubt more costly job. Luckily I've managed to salvage what's left of the top plate so I have a pattern to work to. Sadly this area of rust saw the demise of many bx's.
How much evidence outwardly was there of the rot within.
x 138
Re: Tin worm
None really it started out as a few holes in the sill, after cutting that away it revealed a very rusty inner sill and jacking point which in turn revealing the very crusty axle mounting and inner arch, the rot has all been cut out and several pieces of new steel are currently tacked onto place with a strengthening plate purchased from Chevronics, my 30yr old welder is playing up so when the new one arrives I'll get the job finished
x 113
Re: Tin worm
Respect.
Its now up to us enthusiasts, or whatever we are, to keep on the road the few BXs that there are left.
Re: Tin worm
Been there, done that! It's a real dissection-type job.
