Rear arm
x 137
Re: Rear arm
Hi Mark yes I have some rear arms , the castings are good but most likely will need a rebuild on the bearings and seals etc, the new one I listed has been sold, or I can rebuild your arms if they are usable or rebuild a pair I have here, plenty of options let me know
barry badger
Re: Rear arm
Post by barry badger »
Hi cliff, i'm in need of an osr, non abs arm suitable for rebuild. The one on my txd which is still in use is too far gone and one i had on a spare subframe is also too far gone.
Barry
1993 tzd estate, on sorn
1991 4x4 estate, on sorn
x 137
Re: Rear arm
Hi Barry, I should have a few I will let you know Friday.
barry badger
Re: Rear arm
i've managed to sort this out now, i had to build an arm up with weld and get it back to size with a die grinder and flap discs.
thanks anyway.
Re: Rear arm
barry badger wrote: Wed Jul 25, 2018 12:01 am i've managed to sort this out now, i had to build an arm up with weld and get it back to size with a die grinder and flap discs.
thanks anyway.
Been there, done that ;-)
x 137
Re: Rear arm
That's what bx ownership is all about.
