rear height corrector valve leaking
petermorrisminor
My Cars: There will always be a BX unless they BX rated. Citroen BX 14 st tropez
Post by petermorrisminor »
Have just failed the MOT due to rear height valve leak.car covered 78k miles. every thing working normally.
any one with ideas please on repairing it or sourcing a replacement.
x 83
Re: rear height corrector valve leaking
It is usually a leaking return hose
If it's really the HC then Pleiades can supply repair kits.
x 83
Deleted dupe.
x 137
I have a good used one if you need, but as Jaba says Pleiades can supply you with an exchange refurbished unit for around £100
petermorrisminor
FOOL ! THERE WILL ALWAYS BE A BX UNLESS THEY BX RATED.
I asked for advice re my BX14 with rear height correcter leak failing MOT was told watch leakback pipe.
removed it and saw inch long rubber pipe connecter to H/C was swollen at end .blew on it to reservoir and noticed resistance .this is normal but i put in thin screwdriver to check rubber sound and accepted it !! only when i had CHANGED BOTH DIAPHRAMS and COVERS did i realise that that pesky rubber connecter had a split in it that only showed with LARGE screwdriver pushed inside. i had done all that work with £37 paid for bits sent from FRANCE!
moral must be check those connecters RIGOROUSLY . :oops: [-X
