Wanted FDV and badges
Patch12
My Cars: Dyane,Ami 8,ZX Break,AX 1.5d,Pluriel,BX 17 TZD Turbo,C15,BX 19 TXD
Post by Patch12 »
Hi am after a good FDV or kit to reseal kit,believe part number is 95669034 and rear badges BX17 TZD TURBO & CITROEN that go on the tailgate.Mines a n H reg.Thanks
x 138
Re: Wanted FDV and badges
Pleasures will supply a seal kit for the flow valve or an exchange unit.
deltic
x 49
Post by deltic »
Auto correct? Did you mean Pleiades in Sawtry? That's where I got my FDV from.
2016 Volvo V40 T2 R-Design Pro, blue, 34,000 miles
x 138
Yeah that'll be it.
Patch12
Post by Patch12 »
Thanks will look into that if i cant get a used one:)
x 138
If its just the flow valve I might have a good s/h one but it wont have the pressure regulator on it.
Patch12
Post by Patch12 »
Hi thanks that might be just the job!can you post it if that’s ok?if you can pm me and let me know how much pls.thanks 🙂
Patch12
Post by Patch12 »
Any luck anyone? Someone must be breaking one or have some bits lying around!:)
x 138
Found one let me know if you still need.
Patch12
Post by Patch12 »
All sorted with the FDV now thanks but still need the badges:)
Patch12
Post by Patch12 »
All sorted now!
