Wanted FDV and badges
Patch12
- My Cars: Dyane,Ami 8,ZX Break,AX 1.5d,Pluriel,BX 17 TZD Turbo,C15,BX 19 TXD
Hi am after a good FDV or kit to reseal kit,believe part number is 95669034 and rear badges BX17 TZD TURBO & CITROEN that go on the tailgate.Mines a n H reg.Thanks
Re: Wanted FDV and badges
Pleasures will supply a seal kit for the flow valve or an exchange unit.
deltic
- x 50
Auto correct? Did you mean Pleiades in Sawtry? That's where I got my FDV from.
Yeah that'll be it.
Patch12
Thanks will look into that if i cant get a used one:)
If its just the flow valve I might have a good s/h one but it wont have the pressure regulator on it.
Patch12
Hi thanks that might be just the job!can you post it if that’s ok?if you can pm me and let me know how much pls.thanks
Patch12
Any luck anyone? Someone must be breaking one or have some bits lying around!:)
Found one let me know if you still need.
Patch12
All sorted with the FDV now thanks but still need the badges:)
Patch12
All sorted now!
