Hi Guys, now the weather is allegedly improving it is time to make a start on getting the old girl to start !!
Compressions & sparks are good but no fuel is getting through to the injectors when the engine is cranked over.
Fuel is pumped as far as the fuel rail when the ign switch goes through to start but when the switch is released back to the run position the fuel stops flowing,is this normal?
Surely the pump should be running in the 'run' mode on the ign switch? Any ideas/pointers would be appreciated before I attempt to give it a go on Tuesday.
Many thanks in advance
Regards
Mac
BX mk1 16v Fuel pump issue?
- My Cars: Bx 16v, Riley Elf, Volvo V60 D5, Clio 200 Sport
- My Cars: Peugeot 308 CC
Citroen XM V6 ES9
Citroen Xantia V6
Jaguar XJ-S V12 - x 57
Re: BX mk1 16v Fuel pump issue?
It is designed so that the pump stops when the engine is not turning as a safety measure in case of an engine fire.
Thank you for the reply, I will give it a go on Tuesday, weather permitting !!
Regards
Mac
Regards
Mac
- x 91
If the injectors aren't firing, it might be worth checking the injector relay (next to the fuel pump relay).
