Clock with its own sense of time
vulgalour
1987 Citroen BX 17RD
Post by vulgalour »
I don't have a digital clock in my BX, I've got an analogue one instead. Thing is, it has its own approach to time keeping. Sometimes it runs perfectly normally, other times much too fast, other times far too slow. It never stops, it just never runs at the same rate. I have no idea what could be wrong with it or how to fix it, do you?
x 62
Re: Clock with its own sense of time
Quite normal don't think I've had one that kept good time,, I'm sure you could buy a 12v quartz motor and retro fit.
vulgalour
Post by vulgalour »
The time it keeps is magnificently wrong whatever time of day it actually is. Fitting a replacement motor is a good idea though, not thought about that, might mean I have a clock that's actually quiet then too.
x 62
They are available on ebay for a few pounds tho fitting the hands my require an amount of wizardry..
jamescarruthers
x 14
Post by jamescarruthers »
I have a vague memory that I spoke to Speedycables about repairing mine and they said they could probably do it. I may have just imagined this though!
1987 Volvo 480 ES
1992 Renault Master Mk. 1. Machzone Chateau camper. 2.0 LPG
Previous BX's:
A966 XRL -- BX 16 TRS
H767 BEG -- BX 14 TGE
B316 AMP -- BX 14 E
vulgalour
Post by vulgalour »
After having the dashboard in and out a couple of times, the clock is somewhat quieter now and appears to be keeping time properly so I'm not really sure what's going on with it.
I did notice that the binnacle that's fitted is slightly different to the original. A previous owner replaced the binnacle because the original one had a burnt PCB. The connectors for the clock and the casting of the whole back of the original binnacle is different. There's other differences too, like the complete lack of ABS filter on the original binnacle where the replacement has a slot for it. The replacement binnacle works perfectly fine, so it's not really a problem, just an observation.
