Athena
Re: Athena
The knocking on the front can also be caused by drop links, bottom ball joints or wishbone bushes
Worth checking all of these as I suspect they are prob all 30 odd years old. The struts themselves can also cause a knocking noise tho less likely.
petergar
- My Cars: Citroen BX Athena, RBS8 hillclimb car, VW EOS
Re: Athena
Thanks.....I will check them all.....it passed an MOT so I suspect it's probably the drop links. I don't have photos yet but I will see what I can do....and then try and fathom the system for posting on here!
petergar
Re: Athena
Still don't know where the paint code is?
jamescarruthers
- x 39
Re: Athena
Paint code location: ?viewtopic.php?t=322
Paint codes: ?https://www.bxclub.co.uk/forum/viewtopic.php?t=16488
BX Club forum search function? is the little magnifying glass in the top right or here: https://www.bxclub.co.uk/forum/search.php
1987 Volvo 480 ES
Previous BX's:
A966 XRL -- BX 16 TRS
H767 BEG -- BX 14 TGE
B316 AMP -- BX 14 E
Previous BX's:
B316 AMP -- BX 14 E
petergar
Re: Athena
No numbers in yellow but the car is pale gold - there are letters ECZczw (might not be right I am going from memory) and the link in that thread doesn't work. I am aware of how to use a search facility!jamescarruthers wrote: Sun Aug 25, 2019 2:22 pm Paint code location: ?viewtopic.php?t=322
jamescarruthers
- x 39
Re: Athena
ECZ is Sable which is a pale gold as, you say. A great colour, your car must look v smart.
Here's a Sable XM and C6 for comparison:
Last edited by jamescarruthers on Sun Aug 25, 2019 11:21 pm, edited 2 times in total.
1987 Volvo 480 ES
Previous BX's:
B316 AMP -- BX 14 E
Previous BX's:
B316 AMP -- BX 14 E
jamescarruthers
- x 39
Re: Athena
Re: the possible heater tap being stiff, I think these used to be available from Chevronics in Hitchin; but that information might be out of date.
+441462455280
[email protected]
Once you find it (difficult! It's well in the footwell and you'll get one hand on it if you stretch) you might be able to move it to a different temperature for the winter weather if you can get your hands on it. This is a stop gap solution until you get a new tap. I exercised mine and it did get a little easier to turn the heater control panel but I couldn't get the full range of travel to get full-hot or full-cold.
It is often thought on here that Radweld being used in the system causes these to get gummed up.
+441462455280
[email protected]
1987 Volvo 480 ES
Previous BX's:
B316 AMP -- BX 14 E
Previous BX's:
B316 AMP -- BX 14 E
petergar
Re: Athena
Yes that looks like the colour. I'd printed off the heater tap replacement guide, school holidays are ruining my car time! Once the little buggers go back to school I will get my week day days off back again and progress will be made. The engine is a bit smokey when cold which I assume is valve stem oil seals and I am not sure the auto choke is working properly......I ca see that some models had a manual choke which would be a much better idea!
jamescarruthers
- x 39
Re: Athena
Good luck with it.
I think I had auto choke on one BX and had to read the hand book on how to start it at different temperatures. You may have read this already but to me it was a surprise as I'd only driven manual choke or fuel injection cars previously.
1987 Volvo 480 ES
Previous BX's:
B316 AMP -- BX 14 E
Previous BX's:
B316 AMP -- BX 14 E
Re: Athena
I've seen this car at the northern rally in 2017.
A tidy car but yes it has a set of 16v grey/silver wheels fitted to it. It should have 165/70R 14 tyres
That is the only Gold one I know off as they were mostly all grey or blue.
petergar
Re: Athena
Yes - that's my car.....it's rust free---a few dents and at some point I will get the alloys refurbished....even thinking about getting them painted the same colour.....or is that too much?
petergar
Re: Athena
Well.....I've ordered a new heater control panel from Ebay to replace the broken one......and I wondered - why does the blower fan knob have a cable attached to it? The controls for it are via the circuit board surely?
- x 116
Re: Athena
See Vulgalour's current posting for clarificationpetergar wrote: Mon Aug 26, 2019 9:53 pm Well.....I've ordered a new heater control panel from Ebay to replace the broken one......and I wondered - why does the blower fan knob have a cable attached to it? The controls for it are via the circuit board surely?
petergar
Re: Athena
I am not sure what post you're talking about? I've seen the fan resistor thread and the heater tap replacement but I can't see anything that says why there is a cable as well as the electronic connections?Jaba wrote: Tue Aug 27, 2019 8:29 amSee Vulgalour's current posting for clarificationpetergar wrote: Mon Aug 26, 2019 9:53 pm Well.....I've ordered a new heater control panel from Ebay to replace the broken one......and I wondered - why does the blower fan knob have a cable attached to it? The controls for it are via the circuit board surely?
Re: Athena
Deleted: (didn't read the second page of comments before answering paint code location.)
