HP hydraulic pump wanted
petergar
My Cars: Citroen BX Athena, RBS8 hillclimb car, VW EOS
Post by petergar »
for a 1.6 petrol with power steering......please!
petergar
Re: HP hydraulic pump wanted
Post by petergar »
Or any pointers as to where I can get one or get mine rebuilt?
Dave_16v
BX 16 valve Ph 1 past
BX Gti past
BX Gti Auto past
x 81
Post by Dave_16v »
Check with Pleiades for recondition / rebuild.
Pleiades
Unit 12A Brookside Industrial Estate
Sawtry
PE28 5SB
01487 831239
petergar
Post by petergar »
Dave_16v wrote: Thu Oct 10, 2019 8:59 am Check with Pleiades for recondition / rebuild.
Pleiades
Sawtry
PE28 5SB
01487 831239
Thanks I will give them a try if I can't find a replacement......I can't believe there aren't any out there!
x 138
Pleaides may even a reconditioned unit in stock they are exchange units, last time I enquired they were £130 ish for a pump but that was for a diesel.
Or they can rebuild your own unit.
New ones occasionally come up on ebay the last one I saw was £300 odd quid
petergar
Post by petergar »
For the record Pleaides were very helpful but it was basically going to be £200 to re-build my pump (inc. postage.....possibly just under). Chevronics have supplied me a second hand one for £104 delivered. No more strangled squirrel noises for me! :)
Gasa
Post by Gasa »
What a problem you have with the pump
David
x 60
Post by David »
If you find a goods source of pumps, could you post it on here as I still need one for my BX diesel, but it's not a rush as the car isn't on the road at the minute.
Thanks.
I've got some 2nd hand diesel pumps available, how does £50 including postage sound? Any problems with it & i'll offer a money back guarantee within the first 3mths of owning it, on condition of returning it.
Pedigreed
My Cars: BX Athena 1600
Post by Pedigreed »
Hi all, new BX person here! Question is, when the hydraulic pump gets older can it become difficult to turn and cause the v-belt to squeal? Any info appreciated thanks, James.
Dave_16v
BX Gti past
BX Gti Auto past
x 81
Post by Dave_16v »
Have you checked the belts tension and importantly, condition? If worn, it is worth getting a new one rather than just tightening the old one hoping it wiil bite, that will put pressure on other parts.
Pedigreed
Post by Pedigreed »
Dave 16v, thanks we’re putting new belts on pump and alternator because its been laid up for a few years so we will see if that makes a difference! Fingers crossed that will fix it. Also doing cambelt as a precaution.
