Selling up
Selling up
I've made the decision after 20 odd years of bx"ing to sell up.
The white estate is provisionally sold and I have a stash of spares that also needs to go ideally as a job lot, too much to list but if you look through some of my previous posts it should give a good idea of what I have here, I will try to add some pics or could email them but ideally sell as a job lot
Or if a member of admin could attach any previous listings to this post would be most appreciated
If I have time I will endeavour to list everything over the next few days
Re: Selling up
Ok chaps here you go
Td bottom end short engine good for spares 180k miles
Lhm tanks x2 with caps
Nearside headlamps x4 Lucas valeo good reflectors
Mk2 indicators several
TD bonnet liner good cond
Wiper motor x2 front
Steering column
Td airbox and pipes x2
Bottom steering column cover black
Door mirrors manual x4
PAS pipes x2
TD RADIATOR
Gti8v radiator 19d/16/19
Diesel starter motor x2
Front struts x4
Pair rear struts
Box of electrical switches stalks relays etc
Td engine loom complete
Heater control panels black
Heater control pcb several
Bonnet hinges paid
Bonnet pop cable
Engine mounts diesel TOP middle bottom
Front hubs l/r several pairs
Towbar hatch
Brake calipers front pair
Hyd pumps x2 diesel good for refurb
Bumper brackets f/r
Td gearbox be3 good 80k miles
Pedal boxes manual auto
dash clocks and binnacles td
Front hubs c/w anti rollbar assy complete
Wheel bolts for steels loads
Splash guards
Blaupunkt Boston cc22 unknown working
B pillar lights
Interior lower trims hockey stick black
Set door glass x4 matching tints from a td
Rear arms several
Td inlet manifolds
Intercooler
Heater fan blower
Estate rear light lenses pair of
Fuse box carrier
Rear view mirror
Header tank
Stat housings d
Td pipework heater turbo etc braided
Kkk turbo in bits needs rebuild
Front scuttle panels x2
CAV fuel filters several
CAV fuel pump good
Front grille
Wishbone x2 pair
There are also about 6 large boxes full of brackets/trims/lights/hoses/nuts/bolts/dash trims/clips/more switches knobs dials and other useful stuff
All these parts were from running cars (mostly diesels and turbo diesels) and are in good usable condition. Rear arms may need new bearings but the housings are good
Open to offers on the job lot
I will gladly put it all on a pallet to ship it but this will be £50 ish UK mainland
You are welcome to view and collect
I am approx 6 miles East of Spalding South Lincs PE12
There are also 3 more boxes full of bits in the boot of the estate which I haven't been through yet
Needs to go asap
Steering column
PAS pipes x2
TD RADIATOR
Front struts x4
Pair rear struts
Bonnet hinges paid
Bonnet pop cable
Towbar hatch
Bumper brackets f/r
Splash guards
B pillar lights
Rear arms several
Td inlet manifolds
Intercooler
Heater fan blower
Fuse box carrier
Rear view mirror
Header tank
Stat housings d
CAV fuel pump good
Front grille
Wishbone x2 pair
Needs to go asap
- My Cars: Citroen BX Athena, RBS8 hillclimb car, VW EOS
Re: Selling up
Wow...that is lots of stuff......I need a nice smooth pair of front struts but South Lincs is a long way away
Re: Selling up
I'll gladly send you a pair of front struts, £25 each plus shipping which will be £15
- panky
'88 BX GTi (a long time ago) - x 78
Re: Selling up
I've not been on here long but I've learned that you are a big BX fan and this isn't an easy decision for you and a big change. Hope you sort things out quickly and without too much fuss.
Re: Selling up
Thanks Panky
Yes after many years bx"ing it's time to thin things out I just don't have the time nor enthusiasm anymore tho the red TD will be staying with me as its in a thousand pieces and can't be moved maybe one day I'll finish it.
- Jaba
- x 80
Re: Selling up
Sad news Cliff. We long time enthusiasts are thinning out nowadays. My solution to keeping the faith was to always have a BX as a runner in daily use as far as possible with others, like yours in the wings in various states of repair. Eventually like you it wears thin when you are just fixing up cars all the time. So I have reduced down to one BX. Its in daily use and is a delight to use still and I will keep it as long as it remains as reliable as it has proved to be.
I think in 10 years time a collection of spares like yours and indeed mine will be invaluable to those trying to keep BXs running. Its a pity that we as BXers cannot organise ourselves somehow to store our parts honeypots somewhere through the goodwill of Clubs or enthusiasts .........
I for one will miss you on here.
Re: Selling up
Hi Jaba
Thanx for your kind remarks, I will be keeping the red TD for now after all its been in my possession for a long time 14 odd years and has served me well clocking up in excess of 200k"s in it, I have everything to finish it but no time or inclination but never say never and a prolonged shoulder injury has scuppered future plans.
So I think now is the right time to nip things in the bud.
I will still be checking in to the forum so not completely out of the fold.
By the way I have Yr stalk switch here but the airsc oops on the estate are both broken if you pm me Yr address I'll send the switch over if you still need it.
- Jaba
- x 80
Re: Selling up
Thanks for the update. Yes I still want the switch but I am away at the moment so I will pm my address when I am back in November.
- vulgalour
1987 Citroen BX 17RD - x 105
Re: Selling up
Sad times. I can't help rehome the spares but I will wish you luck!
