BX Wanted £1,000
tzd-92
My Cars: 1990 Citroen bx 16v
1975 Volkswagen camper
2017 Volkswagen Passat
BX Wanted £1,000
Post by tzd-92 »
Hi all hope you're all well!
I'm on the lookout for a BX. I have around £1000 to spend on one. Whats out there? Anything will be considered, obviously one with some MOT would be preferred.
I can be contacted on here or via text/whatsapp on 07786138156
Cheers everyone
Re: BX Wanted £1,000
Welcome back, one will show up.
Don’t be too picky on models, just look for a good example with a long mot
x 138
A solid shell is a good starting point, look for rust in the usual places esp around the rear axle mounts.
£1000 should get you a reasonable mid spec with some mot, listen for knocking at front (droplinks or wishbones) clicking or creaking at rear on the up/down or rear wheels thus /\ (arm bearings) hydraulic leaks, damp carpets/footwells,
Rust is a big BX killer
Headgasket failure
Hydraulic system neglect/failure
Get under it with a torch if poss check for rust and corroded and perished pipes.
Good luck.
seza
My Cars: 1993 BX 1.9TXD
1994 CHEVROLET SUBURBAN
Post by seza »
Hi TZD-92,
I attempted to contact you on your mobile but it won't work,
I might be able to help
please call/txt me on: 0*7*8*0*1*5*5*6*7*1*1
cheers
tzd-92
Post by tzd-92 »
Thanks for the advice guys its appreciated! I've managed to contact seza and we're currently in talks. Cheers
There's a tidy TXD Turbo hatch come up for sale in Portsmouth the other day. K plate, quite a rare car and a rare colour. Think it's £1395.
if its the green one, it looks a great starting point!
