Hydraurincage wanted
Pcheaven
x 12
Post by Pcheaven »
Its official. I give up. I can't find any in the UK.
The bay of thieves had some in France.
it was over £100 inc shipping - not for me.
Is it a secret?, where do folks source this from in the UK
does anyone have 5l they would sell to me and ship to Kent ?( I am in devon next week, so could collect from there if local.
:oops:
ToDo list.
Have a GnT
Have a GnT
3. Adjust the clutch
Have a GnT
Have a GnT
Have a GnT
6. Replace rear spheres
Have a GnT
7. Replace bottom hose
x 138
Re: Hydraurincage wanted
Citroen Classics in Staines keep it in stock (or did) might be worth a try. About £40 for 5 litres
Pcheaven
x 12
Post by Pcheaven »
rutter123 wrote: Tue Apr 06, 2021 8:42 pm Citroen Classics in Staines keep it in stock (or did) might be worth a try. About £40 for 5 litres
Thanks for the tip
I have emailed them
Cheers.
ToDo list.
Have a GnT
Have a GnT
Have a GnT
Have a GnT
Have a GnT
Have a GnT
white exec
My Cars: 1992 BX19D Millesime
1996 XM 2.5TD Exclusive
x 73
Post by white exec »
Looking grim for access to Total's Hydraurinçage.
I presume it's still in Total France's assortment, but will make enquiries.
The Cit part number was 1135001 (5L bottle), but this no longer listed on Parts.
Citroen Classics and GSF show no stock.
I managed to get the last bottle at any Citroen dealer in Spain back in the autumn.
Pcheaven
x 12
Post by Pcheaven »
white exec wrote: Tue Apr 06, 2021 9:25 pm Looking grim for access to Total's Hydraurinçage.
Oh dear
Is it worth popping to France and bringing some back. Assuming it’s readily available. Wonder what the duty would be
ToDo list.
Have a GnT
Have a GnT
Have a GnT
Have a GnT
Have a GnT
Have a GnT
white exec
x 73
I will try to speak with Total tomorrow.
Pcheaven
x 12
Post by Pcheaven »
Sadly they are sold out.
Though hope to have some arrive in approx a month
Also, their workshop is booked fully into November!
They respond to emails very promptly though. Excellent.
ToDo list.
Have a GnT
Have a GnT
Have a GnT
Have a GnT
Have a GnT
Have a GnT
I wouldn't worry, I've only ever used it once and it gummed up my pinion valve. Individually cleaning the filters and fresh LHM is all I've ever needed.
Pcheaven
x 12
Post by Pcheaven »
Kitch wrote: Wed Apr 07, 2021 10:19 am I wouldn't worry, I've only ever used it once and it gummed up my pinion valve. Individually cleaning the filters and fresh LHM is all I've ever needed.
Cheers. Good tip.
ToDo list.
Have a GnT
Have a GnT
Have a GnT
Have a GnT
Have a GnT
Have a GnT
white exec
x 73
If the LHM looks clean, and the rise'n'fall of the suspension is without jerks, then a change of fluid is probably all that is needed.
Where H'rincage comes in is where the fluid is dirty. It is LHM + several gentle cleaning solvents, and will remove the black sediments that form on the hydraulic internal surfaces.
Total UK are coming back to me to confirm the supply situation.
white exec
x 73
Total Hydraurinçage
Hydraurincage 5L.jpg (15.55 KiB) Viewed 1587 times
With this product now unavailable almost everywhere, I have had this today from Total UK:
" Thank you for your enquiry into the above product. I have done some investigation and this product was withdrawn from the UK market in 2012, as a company we did continue to manufacture this for other markets for several years more, but this was withdrawn globally in 2018. I have been advised by our UK technical manager this was a product used to flush the system before toping up with a LHM fluid, I have been advised the product to use for the flushing now would be the LHM fluid itself. "
The previous Citroen part no. was 1135001 (1 × 5-litre) , but this has now been deleted.
Pcheaven
x 12
Post by Pcheaven »
That settles that then
Many thanks
Pretty sure many people will be interested in this.
ToDo list.
Have a GnT
Have a GnT
Have a GnT
Have a GnT
Have a GnT
Have a GnT
RobC
My Cars: 1991 Citroen BX 16v
x 30
Post by RobC »
I reckon if you were really keen to flush the system with a thinner fluid you could dilute normal LHM with a bit of diesel or something (make sure not to leave it in for long!).
But ultimately if things are working ok then just a fluid change and clean of filters is all that’s required (and less likely to cause unforeseen problems too!)
x 116
I am with Kitch on this. In 30 years and 500000 miles of BXing I have never found the necessity for it. Just renewing the LHM and cleaning filters and reservoir has done the job for me. It is the equivalent of vacuuming down the back of the sofa to me, some people like to do it.
jamescarruthers
x 39
Post by jamescarruthers »
Martin at Pleiades once told me that they used to make their own before the Total product existed. Maybe give them a call and ask if they will divulge the secret formula or maybe news of Hydraurincage’s discontinuation will give them the idea to start selling their own again. They post their pipes and stuff worldwide.
I suspect the addition of diesel is indeed a possibility but I wouldn’t like to guess how much. I would trust what Pleiades say though.
I don’t think LHM is magic, just a mineral oil like MIL-H-5606 or Aeroshell Fluid 41 and that you couple just use a generic flushing oil meant for that sort of system.
All of this sounds a bit to much effort though and you could start with a complete oil replacement, including a damned good bleed at the brake and a filter clean (in petrol).
Last edited by jamescarruthers on Wed Apr 07, 2021 4:55 pm, edited 2 times in total.
1987 Volvo 480 ES
Previous BX's:
A966 XRL -- BX 16 TRS
H767 BEG -- BX 14 TGE
B316 AMP -- BX 14 E
