PcHeaven's 91 Meteor. One owner 18,000 miles
white exec
My Cars: 1992 BX19D Millesime
1996 XM 2.5TD Exclusive
x 70
Re: PcHeaven's 91 Meteor. One owner 18,000 miles
Post by white exec »
Not sure what the actual shape of that hose is in reality.
Assuming you can't find a new replacement for that pt.no., what you could do - to avoid taking the car off the road - is to acquire a used hose from one of the cars currently being broken, and use that as a pattern to obtaining brand new 'universal' straights/bends (eg from Metalcaucho, or any of the other aftermarket hose suppliers), to reproduce the part.
Have just posted some info about their universal items:
viewtopic.php?p=270108#p270108
x 137
Go to a local breakers yard and have a trawl sure you'll find something that could be Heath Robinsoned.
Pcheaven
x 12
Post by Pcheaven »
Today’s mini task
Door speaker upgrade.
The factory speakers, even 30 years ago, are terrible
This mini upgrade was cheap, with a noticeable increase I. Range and volume before distortion sets in.
Will add tweeters and a under seat sub as time permits.
ToDo list.
Have a GnT
Have a GnT
3. Adjust the clutch
Have a GnT
Have a GnT
Have a GnT
6. Replace rear spheres
Have a GnT
7. Replace bottom hose
Pcheaven
x 12
Post by Pcheaven »
Tyre inspection day
Fronts are mismatched and 4 years old. Plenty of tread
Tears are 20 years old with plenty of tread.
Ergo. 4 new tyres ordered
Bosch 4 way spark plugs fitted.
Rear wiper blade replaced
ToDo list.
Have a GnT
Have a GnT
Have a GnT
Have a GnT
Have a GnT
Have a GnT
x 150
What tyres did you go for, I've got Michelins on my 3 as per OE, got 165/70 for £50 a corner online
Pcheaven
x 12
Post by Pcheaven »
Today, after 10 minutes research on this forum and 5 minutes work I resolved the issue with. the cooling fan not coming on often ( as far as I could tell )
The connectors on the sensor at the bottom of the radiator were " proper manky". The attached plug was in the same condition and not properly connected.
A quick clean of all connectors and a fan test by individually shorting out the common pin to the 2 speed connectors confirmed the fan was all ok.
Had a cup of tea with engine running just to confirm the fan was working as designed - happy days.
ToDo list.
Have a GnT
Have a GnT
Have a GnT
Have a GnT
Have a GnT
Have a GnT
Pcheaven
x 12
Post by Pcheaven »
Today was electrical day.
In order to cure my first world problem of having to turn on the radio and the CarPlay unit every time I start the car, ( and when I stop the car) I rewired both the cigarette lighter and the radio to a new Ignition live supply. ( my CarPlay runs of the cigarette lighter). Its the little things
A couple of piggy back fuses and some new cable
I did attempt installation of a Alpine 173BT car radio. Sadly it was defective so that will continue another day.
Installed the under seat JBL Sub. sadly I can't test it until a new radio arrives.
I had forgotten what a nightmare the wiring Is behind the radio, and the crazy short aerial lead ( 10cm extension now ordered)
Oh,whatever the Haynes manual says about accessing the cigarette power connector - it suggests removing the front facia - wasn't ideal.
For me - it was impossible. The panel would not come loose. Its far easier to remove the glove box, clock and trinket tray
ToDo list.
Have a GnT
Have a GnT
Have a GnT
Have a GnT
Have a GnT
Have a GnT
white exec
x 70
Infuriatingly short coax aerial leads are a long PSA tradition, with only enough of said lead available to get the plug back in as the radio is pushed back into its housing! Unforgivable, but with heritage. #-o
Pcheaven
x 12
Post by Pcheaven »
white exec wrote: Fri May 28, 2021 10:15 pm Infuriatingly short coax aerial leads are a long PSA tradition, with only enough of said lead available to get the plug back in as the radio is pushed back into its housing! Unforgivable, but with heritage. #-o
Yes, you need hands the six of a small monkey to connect the aerial to the radio.I have ape like hands, so have no chance of getting behind the radio.
ToDo list.
Have a GnT
Have a GnT
Have a GnT
Have a GnT
Have a GnT
Have a GnT
