Shaky wing mirror
RobC
My Cars: 1991 Citroen BX 16v
x 26
Shaky wing mirror
Post by RobC »
The glass in my offside wing mirror is very juddery.
Is this an easy fix? Will I need a whole new wing mirror or can I just replace the glass and whatever it is that holds it steady
x 137
Re: Shaky wing mirror
The glass can be replaced if you can find one
I have good s/h one if u need electric or manual
RobC
x 26
Post by RobC »
Thanks- how is the mirror attached to the body, does it just pop off?
x 83
Look just above the mirror around the middle for a tiny little locking lever, it might equally be below the glass due to the time lapse since I last removed one. Move this fully in the direction it will go sideways and the glass can then be removed. It may be that the metal internal housing has broken off from the external plastic housing or it may just be loose. Once off you can check out the cause.
white exec
My Cars: 1992 BX19D Millesime
1996 XM 2.5TD Exclusive
x 70
Post by white exec »
I have vague memories of mirror glass replacement - very vague.
Haynes ("Mirrors") details two types of door mirror glass replacement, different for Hohe and Britax fitments, and how to tell them apart. One involves springs, the other adhesive. :(
Pcheaven
x 12
Post by Pcheaven »
RobC wrote: Mon Jun 07, 2021 7:44 pm Thanks- how is the mirror attached to the body, does it just pop off?
If I remember correctly. A couple of screws holds it in place
Remove the door card for access.
It’s an easy job. Screwdriver /torx tool and something to pop the door card off
ToDo list.
Have a GnT
Have a GnT
3. Adjust the clutch
Have a GnT
Have a GnT
Have a GnT
6. Replace rear spheres
Have a GnT
7. Replace bottom hose
