BX 16v cooling radiator
-=RAMZES=-
Post by -=RAMZES=- »
Hi, to everybody.
I need new cooling radiator for my BX. As I know it's unique and was installed only in BX 16v. It's made of cooper, and have it's own design.
Original part number is 95636832. I can't find aviability of orginal radiator or any options of other producer.
Mine radiator is in bad condition.
What options of solution do you know?
Thanks in advance.
white exec
My Cars: 1992 BX19D Millesime
1996 XM 2.5TD Exclusive
x 73
Re: BX 16v cooling radiator
Post by white exec »
Hi!
That part number is the right one.
Autodoc (available in several countries - not sure where you are based) has a choice of several makes under that number, including copper/plastic...
https://www.autodoc.co.uk/car-parts/oem ... 095636832#
Dave_16v
BX 16 valve Ph 1 past
BX Gti past
BX Gti Auto past
x 68
Post by Dave_16v »
There have been listings on eBay for a while but it's something of a risk because I read someone fitted one and it leaked. The main drawback is you are dealing with China so returning etc. will be problematic.
A lot of companies show prices but have no stock,. Autodoc for example, messages reading currently out of stock (but they won't get any).
You could look at restoration but they like to see the radiator in most cases to check suitability.
Chevronics had one previously, their listing is out of date as they wanted over £425, OOS now but you could ask.
https://www.chevronics.co.uk/product/bx ... cba1185463
https://www.ebay.co.uk/itm/274030820026 ... BMiLqZhdJf
-=RAMZES=-
white exec wrote: Tue Jan 25, 2022 6:59 am Hi!
Hi, thanks for reply. I saw that list earlier, but no one supplier confirm that any of this options could be bring into Ukraine. Too rare position.
-=RAMZES=-
Dave_16v wrote: Tue Jan 25, 2022 8:40 am There have been listings on eBay for a while but it's something of a risk because I read someone fitted one and it leaked. The main drawback is you are dealing with China so returning etc. will be problematic.
I completely agree
Several months ago I contacted directly with Chinese producer of this radiators. He offered 85 USD for each example, but only if order 10 pcs. He is not presented on any trade platform such as Alibaba or Aliexpress, where I could order 1-2 pcs. You can imagne profit the seller on Ebay)) So I'm still looking for options to buy in Ukraine or maybe Poland.
https://cnjagrow.en.made-in-china.com/p ... -1994.html
white exec
x 73
This looks a difficult one... Just an idea:
Several of the BX diesels were fitted with large and high-capacity radiators - and twin fans - especially where caravan towing was to be done.
If it's any help, we can look at the size of these, and check availability. There is, for example, a company that will accept orders from Mister Auto (owned by PSA), and dispatch virtually anywhere globally. The diesel radiators are much easier to find.
Can you let us know what radiator arrangement you have there at the moment: is it the standard (original type) part, with the 956.... number you posted above? Do you have twin fans? Air con? Some photos of what's there could help too.
Kaapelimies
x 16
Post by Kaapelimies »
In 16 Valve the radiator is under the slam panel, not behind it as in other models. I'm quite sure none of the others will fit (never owned one thouhg).
white exec
x 73
The Ebay (Chinese) one is the only one I've managed to find available.
Drawn a blank on all other makes.
Size appears to be 530wide x 287high x 36thick, so less tall than all the others.
Have PM'd Vanny to see whether he has any ideas.
Kaapelimies
x 16
I think the original radiator is made out of brass, so it can be fixed by a professional, if it's not broken in an accident that is. In which case the cells can be renewed and the old end fittings be kept if survived. I'm sure this can be done in Ukraine, finding the guy can be the problem..
