Wanted: Heater Tap / Oil Cooler / Entire Car
Josh2109
My Cars: 1992 Citroen BX Break 1.7 TZD
1988 Zastava 311
1992 Honda Prelude 2.2 Si VTEC
1994 Skoda Favorit Forman
1995 Volvo 940 2.3 SE Estate
2000 Honda Insight
2001 Mercedes SLK320
2001 Mercedes E430 Estate
2001 Subaru Legacy Outback H6
2001 Mitsubishi Shogun Sport V6 Elegance
2008 Renault Clio 1.2 Expression
Post by Josh2109 »
Hi all,
I need a few bits for my TZD - in a previous life it has had the connector for the heater tap snapped off by a garage, and the oil cooler has a hole in it so has been looped out also. If anyone has these going spare for a diesel then I'd be interested seeing as the cost of the heater tap alone from the usual places is eye watering.
Alternatively, I'd consider a whole car if there's a car going for parts within striking distance of East Sussex - I've got a trailer with a winch so it doesn't need to be a runner and I can be flexible with uplift.
Cheers,
Josh
womble3go
Re: Wanted: Heater Tap / Oil Cooler / Entire Car
Post by womble3go »
pm you.
white exec
My Cars: 1992 BX19D Millesime
1996 XM 2.5TD Exclusive
x 73
Post by white exec »
Substantial number of BX service parts still available new on Mister Auto (although they suffered badly in UK as a result of Brexit) and Autodoc, so worth looking there as well as at breakage.
x 138
Heater taps sticking/breaking is not unheard of on bx's and also a job you only wanna do once so do it right and do it properly, if you're a contortionist or already have the dash out makes things easier, don't loose the little clip either.
The oil coolers are available as they're not specific to the bx
Josh2109
1988 Zastava 311
2000 Honda Insight
Post by Josh2109 »
Cheers all - I found the heater tap issue whilst sawpping my heater matrix out, I knew these were an issue so checked it whilst I was there. I've PM'd folks back so hopefully will get one sorted soon.
RE the oil cooler, I can find loads of XUD ones online but none quite look like mine - I read somewhere that there were two types and that they aren't interchangeable?
white exec
x 73
Josh, if you can post your VIN number, we can odentify the correct current part number for the oil cooler.
This usually lists the unit's thickness (depth), which did vary across various models.
OE part number also will cross-reference to new aftermarket replacements.
Josh2109
1988 Zastava 311
2000 Honda Insight
Post by Josh2109 »
white exec wrote: Fri Feb 18, 2022 6:25 am Josh, if you can post your VIN number, we can odentify the correct current part number for the oil cooler.
My VIN is VF7XBEL0007EL3623 :)
white exec
x 73
Hi Josh,
Cit Parts listing car as:
RP5518 (= 18Dec1991)
5dr Estate
XUD7TE
BVM5
power steering
depollution
RHD
rear electric windows
air con
Oil cooler/heat exchanger is pt no 1103C9, now NFP from Citroen...
? Click to enlarge
Its height listed as 47.6mm, and will have the central tubular bolt to match.
Possible to fit other sizes, if you also have the matching bolt (which is M20 thread, both ends).
Found new 1103C9 here:
Autodoc uk, at €158.90
Pieces de Rechange Classic (PSA's Heritage site), at €149
The item was also fitted to other vehicles with the same/similar engine:
BX XUD7TE oil cooler 1103C9.JPG (23.61 KiB) Viewed 11402 times
Also fitted to Peugeot 405 II (with similar engines).
x 138
I'm pretty sure when I replaced mine some years ago I used an early type cooler from a Berlingo van 1.9d but as/\ says there are 2 different length bolts , my guess is that the fatter cooler is largely for turbo engines.
white exec
x 73
The larger engines just got thicker coolers. So long as tubular bolt and cooler match, it will be ok.
Worth replacing the circular seal behind the cooler (#12 above) - mine leaked annoyingly. Still available from Citroen, and not the same (on BX) as the ring on the oil filters, unfortunately.
The steel coolers seem less prone to internal corrosion/perforation than the aluminium ones. If yours is aluminium, be scruplulous about good quality coolant all year round. (Internal perforation allows engine oil to be injected into the lower pressure cooling system - obvious if you look into the radiator/header tank, as it floats to the top. A v.nasty clean-out job... :( )
Dave_16v
BX 16 valve Ph 1 past
BX Gti past
BX Gti Auto past
x 78
Post by Dave_16v »
Hi Josh,
Re the oil cooler, some are not specific to PSA alone and are used on other vehicles such as Renault and Alfa.
Yours could well crop up used or maybe even new for a different car brand altogether, some solid searching may help, the part number may keep returning Citroen though.
Getting a cross reference could help open up other avenues for your search. 🤞
Josh2109
1988 Zastava 311
2000 Honda Insight
Post by Josh2109 »
white exec wrote: Sat Feb 19, 2022 5:46 am Cit Parts listing car as:
5dr Estate
XUD7TE
BVM5
power steering
depollution
RHD
air con
Interesting it has it down as aircon, it's something I'd love in the car but it's definitely not fitted.
Thanks for looking up the part number for me, I'll see if I can find a cross reference for it and see if that widens the net as those prices are pretty wild!
