panky
'88 BX GTi (a long time ago)
x 169
Post by panky »
Embarrassing school boy error, drive shaft not properly engaged in the CV joint :oops: All sorted now and DKK is back to his wafting best :D
panky
x 169
Post by panky »
The bearing extractor kit arrived this morning. Two days too late but I guess it will come in useful at some point. The lack of the kit, and a seed of an idea from Jaba, made me think a bit and achieved the required result with what I had to hand :D
tom
Citroen Sorceror
x 38
Post by tom »
Over the last two weeks, camshaft oil seals, cam cover gasket and breather pipe. New water pump, timing belt and tensioners, engine mountings apart from lower one to do, discs and pads all round and a brake bleed, a rear arm bearing, fuse box mods, front struts rebuilt and timing belt plunger mod. New driveshaft and seal LHS. Engine and gearbox oil change. Today, if the bits arrive, I have a steering ram to change, the lower engine mount and drop links. Next week, I shall be rebuilding the FDV and that ought to be it for a while, at least mechanically. Was it worth it? Definitely. Taking a basically sound thirty three year old car and refreshing all the bits that have worn out makes it a great deal better to drive.
panky
x 169
Post by panky »
You have been busy. I took me three days to do a wheel bearing so I'm impressed. It was my first attempt so hopefully I'll be better prepared in the future.
Dave_16v
BX 16 valve Ph 1 past
BX Gti past
BX Gti Auto past
x 76
Post by Dave_16v »
Started it, let it run a while while it lifted up. It's getting out on Thursday.......... as far as the drive 😂. Probably get a few glances as usual. A lady passing spotted it in the garage a while back, covered by a dust sheet. Asked if it was a BX as she once owned one and recognised the lines. She attended classic meets and shows, said it would get lots of interest.
I told her I had always planned to use it but things have to take priority just now and for the foreseeable.
