Heater Matrix Swap
panky
'88 BX GTi (a long time ago)
x 171
Heater Matrix Swap
Post by panky »
The drivers side carpet continues to get wet and a piece of kitchen roll pushed up the centre console heater vent shows that it's coolant, red oily Evans Waterless :? So all prepped with a new matrix and seals, system drained, relevant lower dash trim removed and a big towel in the foot well I contorted myself enough to remove the four bolts securing the pipes to the heater valve and the two self tappers locating the matrix, what a palaver. Had to drop the steering column to wiggle the old matrix out, it didn't come out in one piece.
Shiny new one
So it came to fit the new one, simply a reversal of the removal - yeh right. I got it in OK but the outlet flanges were about half an inch away (too long) from meeting up with the heater valve, there was no way it was going to fit. Wrong matrix?
Looks OK to me
So I tried to put the old one back in and it's the same 1/2" out. I'm stumped as there doesn't seem to be anyway anything could have moved, it's all solidly mounted.
Had enough today so I'll think on it and try again tomorrow. Any and all suggestions would be welcome.
panky
x 171
Re: Heater Matrix Swap
Post by panky »
After another frustrating day on my back in the footwell I managed to get the new matrix in through brute force and ignorance. Using a well greased scraper blade between the flanges I managed to force the heater onto the valve and bolted up. Unfortunately when I re-filled the system the joint pi$$ed out so I guess the new seals got displaced when the scraper was pulled out, luckily I bought a couple of sets.
I'm having day away from it today as I have a feeling nothing good will happen when I pull the matrix back out :cry: If it does come out in one piece I might try shaving some of the fins off to git a little more clearance.
