Hi all.
In changing the long hydraulic pipes I've dropped petrol tank and to do this the long rod for suspension control and the assembly which the rod hooks into for the height corrector operation.
The only way I can see how to reassemble the linkage now the tank is back in is for the arm which rotates maybe 10 degrees to pivot on its threads, which doesn't seem right.
Basically I've forgotten how it went.
Can anyone advise.
I watched a clip on adjusting ride height but it's on a Mk1 (mines 89) and the bracket looks a bit different.
There are only a few compartments making up the assembly.
Long bolt which goes through the bracket on car body, nut and arm with threaded centre.
I've locked the bolt to the bracket with the nut after threading the arm onto the bolt.
It seems to work but like I said uses the thread in the centre to rotate.
I think I'm missing something obvious.
Thanks
Rear height corrector linkage
Kieron g
- My Cars: 2001 Citroën berlingo multispace 1.9d
2000 Citroën berlingo multispace 1.8i
1988 Citroen BX 1.6 RS (sun seeker) - x 10
David
- x 60
Re: Rear height corrector linkage
It sounds like you’ve reassembled it correctly; they only move a little bit. If you’re unsure, there’s a picture of my assembly in the blog section of the site ‘The Myth, The Legend, The Citroën BX 1.9 Diesel Meteor 4x4’ it’s on page 5 and has a picture of how the height rod is assembled on the axle. If you compare mine against yours then you’ll know if it’s right.
Hope that helps.
Hope that helps.
Kieron g
Thanks David I'll have a look.
Never seen threads used as a what would usually be a bush before.
I'd of thought a few wet salty winters and these would have seized up but it must have worked okay
