Door unhinged
pindimar
My Cars: no longer any BXs but do have a Xantia
Door unhinged
Post by pindimar »
I shall try to post a picture of the front passenger door hinge rusted off:
Hope this works OK
Greg F (Pindimar)
sleepy0905
Post by sleepy0905 »
Thats savable as it is still partly attatched you can get that welded and plated dont wait till it falls off completely as most people will not touch it at all then.
x 82
does deffinatley look savable! just need to find someone to do it really! The metal in the body work behind has a number of layers all joined up so you'll need to be careful about how its welded and cleaning it all out so it doesn't happen again, but they get done in the UK with reasonable ease and good results!
AndersDK
Post by AndersDK »
Ask around for a good and trusty welder who knows about his job.
I've seen some very nasty & lumpy repairs of this common BX problem.
The last repair job I got done on my TRD is looking perfect - and the hinge is solid - no movement on the pillar while door is moved. My welder is not a Citroen specialist - simply a good craftsman.
You may help the welder by preparing the job this way :
1) unclip the headlamp on affected side
2) unbolt the blinkers lamp same side
3) refit blinker using gaffer tape - clip the headlamp back in
4) now you have access to most of the bolts/nuts holding the wing - remove all bolts/nuts. Clean & greas the bolts nuts - then refit 2 of them handtight to keep the wing located
5) pay special attention to the 2 bolts at rear of wing accessible when door is partly open. These fits into captive nuts.
6) support the door then remove door hingepins and insert screws or nails which are easy to remove at will.
7) support the bracket holding the pin for the door strap. Then tap out the pin. Insert a nail.
8 ) strip the door and unhook all electric connectors - then withdraw complete door loom with the gaiter from the door.
Now the door and wing can easily be removed using no tool.
Only a very brief explanation is needed to get back a perfect job.
This ensures that you dont get your car back with all sorts of minor damages and shortcuts which have to be repaired - like a bunch of cutted wires to the door :roll:
The main idea is of course that you try stay in control of what happens to your car !
pindimar
Thanks Vanny
Post by pindimar »
Thanks for getting that link right Vanny!
Thanks AndersDK for the advice, Actually, it's good to know what should be done for a good job.
Will post a picture of the repair when I am able, then
Greg F
Stewart (oily!)
Post by Stewart (oily!) »
I removed the door pins and hung the door on my engine crane, that way I did not need to disconnect the wiring.
Stewart
TZD 19 TD one of the few
Xantia Td estate, going soft
cauchoiskev
Post by cauchoiskev »
Maybe this will reassure you :
That was the state of my estate's passenger door when I saved it from the breakers. I managed to fix it myself with an arc welder and 2mm steel sheet bashed into shape (I had to replace the steel from the seam down to the cable hole, and right round the corner under the wing).
I did burn a few holes, and the result was made aesthetic with a lot of mastic, but it certainly seems strong enough. It would be a good idea to squirt loads of rustproofing in the pillar afterwards, though, as there will likely be quite a bit a flaking in there.
pindimar
rear door rust
Post by pindimar »
Yes, that looks even more nasty!
Actually, I have the car back from the repairers and it looks quite good! Total cost $500 Australian. I'll take a picture tomorrow and post it as soon as I can.
Greg F
pindimar
Door now hinged
Post by pindimar »
Well, picked up the car from the panel shop and it looks great. They seem to have done a really good job. $500 Australian was the damage
Thanks for the advice from the Group
Greg F (pindimar)
Ian_Fearn
Post by Ian_Fearn »
That looks like a fab job.
Shame Tim Leech cant get his 16v over to you!
Over and out from me
tim leech
Post by tim leech »
True, mind you my 16v wasnt anywhere near that bad. The hinges themsleves on mine are as much.
AndersDK
Post by AndersDK »
Looks like a new pillar has been welded in ?
Certainly looks well.
ed4ferrets
Post by ed4ferrets »
Gregc wrote:K reg, black, good condition, 17 TZD, electric windows x4, electric s/roof, power steering, ABS, no tax, MOT until the end of Jan 07.
Been to see it with Chris Joyce who is after a TD .....
Pretty accurate description with downside being heating fan on max or not at all, and passenger door hanging an a hinge much like Pindimar's
No doubt not a problem for someone with the equipment and knowhow to repair, but otherwise what would be a ballpark UK figure to have this job sorted? Would it be worth doing it on top of the asking price for the car of say £300ish?
'94 XM 2.1TD Break
'63 Renault Caravelle
