Fitting of aircon has commenced and i'm flying along, however, the top section of the dash (where the air blows through from the blower unit) has a crack through it! Rather annoying to me and i just wondered if anyone has a top section in sound condition that they can get to Liverpool in the next few days?
Not a lot to ask i know! But would save me taking it out again at a later date!
WANTED Dash top panel?
- Vanny
BX 16v Ph2 - XPO - x 82
Getting the dash out isnt too hard at all Tim, took me about an hour the other day! Its only held in with 6 bolts (one in each foot well, two in the scuttle and two by the steering rack), tricky bit is taking everything off first to include console, steering wheel, radio, blower controls, glove box, indicator stalks, mirror controllers, courtesy light controller and a few other odds and sods, then cut all the jubilee clips that hold the wires together and pull her out!
At this point it pretty easy to remove the whole blower unit!
I've had a reprieve though, jolly good clean and it seems to be a slight scratch and not a crack so not to worry. Having had a closer inspection the top panel is plastic welded to the dash so not too much chance of that coming off
