Adam's misfortune has been lucky for me, and I've picked up a load of bits.
I have cracks in both the above items. Superglue and contact adhesive haven't worked terribly well. Does anyone have any other suggestions?
thank
Oscar
Repairing sunroof deflector and headlamp protectors.
Oscar
Geoffrey Gould
Plastic glue.
Hi probably time for yellow pages and the nearest supplier of plastic for signs etc. Sorry cant remember what was used, got a feeling it was something like nail polish remover or choriform, some one here is bound to know.
Cheers.
Geoff.
Have used a soldering iron before now, should I have said that?
Cheers.
Geoff.
1991 BX 1-7 td Auto.
NEVER WRONG.
NEVER WRONG.
- Keeper of the site Goat
BX Bandit
- Backslash Bandit
- My Cars: Cars
- x 3
I expect the best adhesive to use is a solvent adhesive which slightly dissolves and bonds the two surfaces. However, the joint must be clean and fit tightly to work (so if you have already tried a glue and cleaned some off and scraped the joint 'clean' then it may not not work) You'll need the correct type of solvent and I suspect that the deflectors are made from Acrylic but I honestly don't know. You should find solvent adhesive in the plumbing dept in B&Q but check for compatibility. If you do use some, don't spill any because it will mark and it wont come off!
An alternative is to try an epoxy glue like Araldite. There is a clear one which holds after approx 90secs (I mended my favourite beer Stein Glass over 2 years ago and it still holds)
Good luck!
Good luck!
