WANTED: LHM tank cap T-piece
RobC
My Cars: 1991 Citroen BX 16v
x 26
Post by RobC »
Hi Folks
An easy want this: anyone got a spare lying about? Bonnet was shut with some force the other day and poor old t-piece shattered.
Can buy a pint of ale in return.
Cheerio :)
Tim2cv
Post by Tim2cv »
I cant undertand the need for a T piece (someone proove me wrong)
The bit heading towards the driver goes to no where so why have it. Some time in the past mine was snapped off and someone has fitted a small length of soft ish rubber hose to the top of the cap then to the other pipe going under the engine some where... does the job and wont snap off!
Scarp yards sometimes have them on cars in there but most break off anyway. Are any of the other Hydro Citros the same?
TIM
2CV6 1986 Dolly
MEHARI 1976
DYANE 6 1981 - GF'S CAR!
www.bx16valve.co.uk/forum
www.myspace.com/tim2cv
djoptix
Post by djoptix »
Agreed, I don't reckon you need the T piece unless the other bit of plastic pipe is a breather or something.
On mine the drivers' side pipe is cable tied to some other stuff, so it looks like it goes somewhere... I only noticed it doesn't after my T piece had broken and I ordered another one from the dealer for about £4 :shock: Schoolboy error!
sleepy0905
Post by sleepy0905 »
The one that goes no where is a breather and without it you can get like i have had where the top pops off and the returned LHM from the other pipe just goes everywhere including dripping on the fan of the alternator which sprays it everywhere.
x 82
but you'll only get that much return if a component is faulty, surely?
The 'other' pipe is the los pressure return from the PAS and N/S strut, these have a union towards the front of the front subframe (behind the gear box) which is also plactic and likely to failure! The official Citroen repair is to simply replace both lines as individuals all the way back to the tank.
LHM also eats alternator bushes (i have TWO alternators to prove it!), so you deffinatley dont want it pouring over that!
Once Rob's sorted, I could do with one too!
Ian_Fearn
Post by Ian_Fearn »
These were available from Citroen last time i checked. They werent silly money either.
Over and out from me
Ian_Fearn wrote:These were available from Citroen last time i checked. They werent silly money either.
Maybe not silly money to you :P
djoptix
Post by djoptix »
Mine cost £4.50! That's silly. Silly of me to pay it anyway ;)
Doesn't the LHM tak cap itself have breather holes in it?
£4.50??! Told ya you were minted Ian :lol:
Well if they're only £4.50 then I'll pop down le dealers.
Ian_Fearn
Post by Ian_Fearn »
I really have no idea where you get this silly notion from! :D
Geoffrey Gould
Post by Geoffrey Gould »
Why not just drill a couple of holes in the cap and push the pipes through, a couple of pieces of windscreen washer pipe 1/2" long on the ends under the cap stops then pulling out. Job done.
Cheers.
Geoff
1991 BX 1-7 td Auto.
NEVER WRONG.
