Wanted: BX16V dials
Wanted: BX16V dials
As above I need a set as mine are broken, pleassssse
cash waiting
cash waiting
- x 88
The red line on the rev counter comes in later, plus they've got all the pressure dials and stuff. Other than that they're the same.
- docchevron
The speedo's different too! Looks the same but the gearings different in it. There are two different speedo heads for the 16v.
The numver on the top of the face is all important!
Chris G
Chris G
- Citroen Sorceror
Yours are broken? Do you mean some are broken or all? Is the problem physical damage or electrical gremlins? The reason I ask is that the binnacle is very repairable with parts from other cars, (we DERVishes regularly strip them down to add temperature gauges from GTIs to our diesels) and If all the dials have failed, you probably need to be looking elsewhere for the source of the problem. The technical forum here will be able to help in either case if you would kindly post up there and explain the problems you are having.
- Cornishbx16v
nice low miler there matey!!!
hjave a look over on www.bx16v.co.uk/forum am sure one of our members has a spare set lying around somewhere!!!!
- x 88
Thats my car?EWP16V wrote:Yeah there broken, i just want to replace them and be done with it. I cant be arsed to fix them as ive done it too many times before. I've managed to get some now anyway.
These are Bx16v clocks by the way
- docchevron
clocks
I have several full sets of proper 16v clocks.
Drop me a pm if oyu still need some
Luke
Luke
