Wanted: BX16V dials
EWP16V
Wanted: BX16V dials
Post by EWP16V »
As above I need a set as mine are broken, pleassssse
cash waiting :)
Keeper of the site Goat
Post by cavmad »
Are they different to standard BX clocks?
Vauxhall apologist.
The red line on the rev counter comes in later, plus they've got all the pressure dials and stuff. Other than that they're the same.
tim leech
Post by tim leech »
GTI 8v ones are the saem except for the revcounter redline.
The speedo's different too! Looks the same but the gearings different in it. There are two different speedo heads for the 16v.
The numver on the top of the face is all important!
Chris G
Post by cavmad »
That`s mine out of the running then as mine are TGD or TXD clocks.
Vauxhall apologist.
Post by cavmad »
Have some GTi clocks I found kicking about, are they any good then or different?
Vauxhall apologist.
tom
Citroen Sorceror
x 38
Post by tom »
Yours are broken? Do you mean some are broken or all? Is the problem physical damage or electrical gremlins? The reason I ask is that the binnacle is very repairable with parts from other cars, (we DERVishes regularly strip them down to add temperature gauges from GTIs to our diesels) and If all the dials have failed, you probably need to be looking elsewhere for the source of the problem. The technical forum here will be able to help in either case if you would kindly post up there and explain the problems you are having.
EWP16V
Post by EWP16V »
Yeah there broken, i just want to replace them and be done with it. I cant be arsed to fix them as ive done it too many times before. I've managed to get some now anyway.
These are Bx16v clocks by the way
Post by cavmad »
The eight valve GTi clocks I have are different, they redline just after 5,000 rpm though the other dials/clocks look just the same.
Vauxhall apologist.
Cornishbx16v
Post by Cornishbx16v »
nice low miler there matey!!!
hjave a look over on www.bx16v.co.uk/forum am sure one of our members has a spare set lying around somewhere!!!!
Timmo.
After all I AM CORNISH!!!!
www.bx16v.com
www.bx16valve.co.uk
tim leech
Post by tim leech »
Oil pressure gauge works too (unlike mine)
EWP16V wrote:Yeah there broken, i just want to replace them and be done with it. I cant be arsed to fix them as ive done it too many times before. I've managed to get some now anyway.
Thats my car? :?
Kitch wrote: Thats my car? :?
Better check it's still there kitch!
Is there a thief in our midst? :D :D
Chris G
Toddman
clocks
Post by Toddman »
I have several full sets of proper 16v clocks.
Drop me a pm if oyu still need some
Luke
Please call me Luke :)
http://www.bx16valve.com
