Found a GTI (8V) at the scrappers today and pulled off the instrument panel to put a water temperature gauge on my diesel. Couldn't find the bl***y sensor, though. No help from Haynes, who only mention the 16V.
Is it in the same place as on the 16V (rear left side of the cylinder block) ? Do you have to pull anything else off to get at it ? Thanks in advance...
GTI 8V : where's the water temperature sensor ?
- x 97
Its on the water housing at the LH end of the head. On the underside right at the back there are two senders, you want the smaller of the two. The other one is the overheat warning.
Not easy to get at !!
- Our Trim Guru
2020s - A shinier red TZD estate has replaced scruffy 19TXD "Red Shed". - x 10
