CV joint or driveshaft change.
tim leech
Which is easier guys, my 16v has a non abs driveshaft and the other the CV is worn out, I have a pair of used 16v drivehshafts I can fit but im told there awkward, and of course they are used and untested so may be not much better.
Can i fit two new correct CVs to the existing driveshafts to cure my problems.
Yeah, it's possible to change the (outer) CV joints, although it's probably easier to change the whole shaft. The N/s shaft is very easy, the O/S shaft is not much harder, you just need to undo the two 11mm nuts on the support bearing bolts. The bearing can corrode into the bottom engine mount but a good bar and a heavy hammer usually gets them out!
If you change the shafts do the diff seals at the same time.
Chris G
Chris G
M
tim leech
M
tim leech
Yep, I'd go for new. If you "enjoy" the valver the shafts have a fairly hard life. ECP are cheaper than GSF and I know last time I wanted some for mine they wern't interested in ordering any, didn't have any in stock, and then tried to fob me off with crap ones. I got genuine in the end, aint killed them yet....
Chris G
Chris G
BX Bandit
- Backslash Bandit
- My Cars: Cars
- x 3
I did the n/s on mine a couple of years ago £26 from GSF IIRC but I think 16v ones are different tho'. Still, a surprisingly cheap and quick alternative to getting dirty with a CV joint!!
tom
- Citroen Sorceror
ECP sold me the right hand one for £73.11+VAT Yesterday and are getting me the left hand one for £35+Vat tomorrow. These are the ABS shafts for a 16V or TD. At that price, I wouldn't bother with the outer joints because the inner ones wear out as well. If ECP's website says that there is no stock, Call a branch up and enquire. You may be pleasantly surprised as I was with the left hand shaft which is supposedly out of stock.
Ian_Fearn
