CV joint or driveshaft change.
tim leech
Post by tim leech »
Which is easier guys, my 16v has a non abs driveshaft and the other the CV is worn out, I have a pair of used 16v drivehshafts I can fit but im told there awkward, and of course they are used and untested so may be not much better.
Can i fit two new correct CVs to the existing driveshafts to cure my problems.
Yeah, it's possible to change the (outer) CV joints, although it's probably easier to change the whole shaft. The N/s shaft is very easy, the O/S shaft is not much harder, you just need to undo the two 11mm nuts on the support bearing bolts. The bearing can corrode into the bottom engine mount but a good bar and a heavy hammer usually gets them out! :D
If you change the shafts do the diff seals at the same time.
Chris G
M
Post by M »
With every car I have ever had CV trouble with the simplest option has been to fit an exchange driveshaft and refill the gearbox afterwards.
Not the cheapest, though at £55 ish an exchange shaft not the most expensive problem either.
tim leech
Post by tim leech »
Can i get 2 new shafts for that sort of money then and where? I dont mind shelling out the cash as long as its right.
M
Post by M »
If you have some shafts already, grease them up and slap them in. Otherwise, GSF, ECP and the ilk used to carry them - may be a case of phoning and seeing where the items are and getting them shipped.
tim leech
Post by tim leech »
The ones I have are used and off a high mileage 16v that was broken up, so if its about a hundred for a new pair I will get some.
Yep, I'd go for new. If you "enjoy" the valver the shafts have a fairly hard life. ECP are cheaper than GSF and I know last time I wanted some for mine they wern't interested in ordering any, didn't have any in stock, and then tried to fob me off with crap ones. I got genuine in the end, aint killed them yet....
Chris G
BX Bandit
Backslash Bandit
My Cars: Cars
Post by BX Bandit »
I did the n/s on mine a couple of years ago £26 from GSF IIRC but I think 16v ones are different tho'. Still, a surprisingly cheap and quick alternative to getting dirty with a CV joint!!
tim leech
Post by tim leech »
GSF want £98 + vat EACH! and as usual ECP says "sorry no stock" :evil:
Post by ken newbold »
Try M&C Lockwood, 01274 640590
If he has one you can get it delivered here. :D
tim leech
Post by tim leech »
Whys that then Ken? I still have your radiator btw!
tom
Citroen Sorceror
x 38
Post by tom »
ECP sold me the right hand one for £73.11+VAT Yesterday and are getting me the left hand one for £35+Vat tomorrow. These are the ABS shafts for a 16V or TD. At that price, I wouldn't bother with the outer joints because the inner ones wear out as well. If ECP's website says that there is no stock, Call a branch up and enquire. You may be pleasantly surprised as I was with the left hand shaft which is supposedly out of stock.
tim leech
Post by tim leech »
Thanks tom, will try that.
Ian_Fearn
Post by Ian_Fearn »
Like Ken said, try M&C Lockwoods. I get most of my parts from them now. Excellent service AND he knows Citroens!
Over and out from me
tim leech
Post by tim leech »
Thanks Ian, also thanks for agreeing to fit them! :D
