Useful Tool
tim leech
Useful Tool
http://cgi.ebay.co.uk/citroen-xantia-2- ... dZViewItem
2.1 Turbo Diesel VSX, MOT and its a R plate, looks smart in red with the alloys. is a diesel pump a easy job?
Anygood to anyone.
Anygood to anyone.
- Keeper of the site Goat
capri
Asked a few questions (i.e. length of MOT, mileage, etc). There's an outside chance that, if nobody else fancies it on here, I might buy it, sort the diesel pump, and sell it on for profit as a working car. Is the diesel pump an easy (read: inexpensive) job on one of these?
1984 Black Ford Capri 2.8 Injection (Specialised Engines Stage II) - Pride & Joy
1996 Hermes Red Citroen Xantia TD SX Estate - Autoroute Cruiser
If you can find a good inj. pump then yeah, it's very easy and cheap to do!
Infact, assuming you can get a good Bosch pump then it'll cost you a couple of
for it to magically find it's way timed up on the engine
Chris G
Chris G
tim leech
Lets not get carried away here matey, it's still a xanty! (OK, I know, I know, I'll stop now, promise), but yeah, the 2.1TD engine is a cracker, especially in an XM!tim leech wrote:its a lot of car for £350.
Chris G
tim leech
hhmm, well, er, each to their own, I just always saw the Xanty as a compromise. It's a poor BX replacement IMHO, and it looks like a miniature XM, except the XM was a better car in every way.
I did own a Xantia once, an ACTIVA, for all of about 30 seconds, and I turned a profit!
Although I must say dad's V6 was a nice machine, again though, it's the engine that made the car.
BX Tint glasses, they'd be the one's with LHM Green tint lenses then??
Chris G
Chris G
M
CRACKKKKKKKKK! Hello Susan, I think Stewart may have a spare 1.9TD engineMarty wrote:Weeeeel
I like both - though oddly I think the Xanty estate is nicer than the BX Estate. (may I be flogged with cherry laces and publicly called Susan for saying that) This one looks lovely - shame its a non runner.
Vauxhall apologist.
tim leech
To be honest it would be a darn site more than £250 if it was! the Xantia estate is a nice loooking car, the Bx is a bit "tacked on" but very practical none the less.Marty wrote:Weeeeel
RichardW
Steady guys.... the 2.1 in the Xantia uses an ECU controlled Lucas EPIC pump. Might not be as easy as just bolting another one in. The 2.1 is also a real shoe horn job in the Xantia, so there's not much room to work on it - might make the pump change awkward. I suppose you could source a mechanical pump from an XM or something, jump a supply to the stop solenoid, and dump the ECU
I NEED a BX TD.
tim leech
I recall a long running saga on the Frenchcarforum about a Synergie with this pump - thing had blown after a clutch change - turned out it had earthed through the ECU - which had blown just after the input plug on a zigzag track on the circuit board! - Could have been repaired with 10 minutes with some sandpaper and a soldering iron!
This one would run but was noisy and lacked power which suggests that thats what they do if the ECU has failed - so - what's wrong with it - as pumps by and large don't give much trouble.
There was also a thread on here mentioning that the 2.1's and presumably the Epic run at higher injection pressures than some (earlier?) engines.
