BX TZD (1.7TD) for sale
jolly_green_giant
J reg 184K miles, new trailing arm bearings (20K ago), new clutch, timing belt, water pump (8K ago), new windscreen and a new bottom ball joint on passenger side. Has a towing hitch. Engine uses very little oil and as far as I can tell is in very good condition for it's age. Taxed and MOTd till April 2007.
Metallic dark green, no obvious rust and vertually none else where! Interior in very good condition!
The only slight problem is air getting into the diesel system It's a connection under the engine but I don't have the time to fix it. It runs fine but if it's left overnight you need to start it twice.
I'm looking for £300 ONO and I'll post pictures when I have my camera back (after 8/10)
edit:- Sorry forgot to mention, based in Hinckley (midlands)
jolly_green_giant
- x 94
PiLsY.
jolly_green_giant
simonbx17
tzd turbo
pm sent
Current.
jolly_green_giant
PiLsY.
Is anyone close enough to take a look? Its a bit far for me for a day out
I'm interested, am definitely after a TD to keep the mileage off the GTi, but this is higher mileage than I was looking for. Other than that though it sounds perfect.
How are the electrics and suspension? Do the heater and blower work ok?
Thanks,
Matt.
Thanks,
Matt.
jolly_green_giant
PiLsY.
mnde
- Meteor Man
Barnsley BXer
